Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
dan79brooklyn's Avatar
Battery replacement for 911sc?
I want to keep the stock mountings and easily found replacement...Do I go with Interstate about $100 and 48lbs. Any other preferences for a good battery brand, Car has been sitting 2-3 weeks between drives.
Old 02-06-2005, 06:33 PM
ruf-porsche's Avatar
SEARS carry a battery that is a bolt in using the stock mounts. I think it their international series.
Old 02-06-2005, 07:11 PM
Don't forget that the lower/front hold-down clamp can be attached in 3 different places up front on the car.....allowing three different length batteries.
The kahuna size we all seem to get from the factory is the longest ( group size 49), but the next smaller group size 48 should work well and give you a bit more room to horse the battery in and out when needed.
Or simply go Optima....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-07-2005, 05:33 AM
I use the Interstate battery......love it. You may want to keep a Battery Tender on it between drives.
Warren & Ron, may you rest in Peace.
Old 02-07-2005, 05:45 AM
earlyapex's Avatar
I have a Sears battery too. You really should look into a battery tender if your car sits that long between drives.
Eric
1978 spec 911
1998 C2S
Old 02-07-2005, 05:49 AM
I also had the Interstate in my SC. It was a perfect fit although a bit
tight. If I had to put another battery in an SC I'd go Optima for the
room.
Old 02-07-2005, 05:51 AM
vash's Avatar
Location: hard to tell, with all the sticking and moving!
you know....i love the optima battery (one in my truck). but the PO put in a brand new interstate battery when he sold me the car, the SC. i sometimes go weeks without driving either vehicle. the truck sometimes sees low voltage, and the SC, NEVER! i expect good things from the interstate. i was going to swap the batteries, but i decided to let things stay as is. i am not convinced that i will buy another optima.
poof! gone
Old 02-07-2005, 09:11 AM
It always seems to come down to Interstate v. Optima!
Never had an Optima, so I don't know about that. Had every other kind of battery, though. Interstate, Sears Diehard, Pep Boys, etc. etc. Of all those, Interstate stands way above. I think the shortest life I ever got from an Interstate was close to 10 years. And that's with abuse - letting the car sit for weeks at a time with no battery tender on it.
The Interstate in my daily driver BMW is at least 8+ years and still going strong.
Old 02-07-2005, 09:16 AM
Optima sounds great but the common report of having to electrecute the thing to revive it has me a bit leary.
Old 02-07-2005, 09:20 AM
Interstate is a great battery...one caution here, though:
The Interstate is a regular battery, and even if it never leaks ( or "spills" on high-G maneuvers)...the off-gassing near the fuse box has me worried. Get the normal battery style that has a small vent "teet"..and run tygon tubing from the nipple to "somewhere" out of the car. Use one of the three or four one-way rubber drain plugs that run left-to-right on the trunk floor just in front of the gas tank....
Wil
Wil Ferch
Old 02-07-2005, 09:27 AM
Thanks for the affirmations: I just finished installing the Intersate battery. It's bigger and heavier than the previous battery. PO had drilled a hole for the bracket to fit the smaller size battery, but it's all good, got a 85 month warranty and delivered for $79.95
started right up ! It was a tight fit there really is very little room to get jumper cables onto a 911sc. hopefully I won't need them for a loong time.
Current Drivers - MKIV GTI & MB E320 Wagon
(saving for another 911...maybe a 996)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
Old 02-07-2005, 05:49 PM
Lorenfb's Avatar
"It's bigger and heavier than the previous battery."
Not good! Bigger isn't always better especially when it comes to Porsche batteries.
The "monster" batteries provide a very heavy current load on Porsche alternators,
e.g. '82 & '83 internal regulated alts. The 3.2 Carrera alts will fail when the "monster"
battery is very low and the engine is revved or driven immediately after starting.
The problem occurs mostly with internal Porsche OEM regulators which are set to 14.70 volts.
The "monster" batteries become a heavy current "sink" when their voltage exceeds 13.75,
resulting in large alt currents (>>30 - 50 amps).
Bottomline: Use a standard size battery. Its' CCAs are more than adequate with
a fully charged battery and good battery connections.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 02-07-2005, 06:12 PM
bairdc3's Avatar
I made the aluminum plate as a mounting plate and used the optima battery. Worked out really nice.
See this thread on how to make it.
Optima battery questions
KarStuff
1980 911sc light blue metallic
2002 Toyota 4-Runner
Emmick go-kart
Old 02-07-2005, 06:27 PM
12 years and 17k posts...
azasadny's Avatar
I love my Optima red top!!
Art Zasadny
2010 MazdaSpeed3 (daily driver)
www.ford.com
Old 02-07-2005, 06:37 PM
My 10 year old Optima just gave up. Replaced with another.
Old on left (800 CCA)
New on right (720 CCA)
Same weight: 35 lbs.
Sherwood
http://members.rennlist.org/911pcars
Old 02-08-2005, 12:30 AM
Don't ignore Loren's comments.....
A big battery....( or one that isn't charged to near-full by a stand-alone high rate charger before it's first use)...will overtax the alternator. You'd be using the car's alternator as a deep-charge unit....instead of the "topping-off" unit it is intended ( and designed) to be.
Also, don't forget the vent tubing...otherwise we talk later about ( big issue) rusted floor pans and suspension pick ups....or ( smaller issue)....electrical issues and corrosion on the too-nearby fuse box. All not to be taken lightly.
Wil
Wil Ferch
Old 02-08-2005, 10:35 AM
Banned
I think You need to go yourmechanic. I already replace a battery for my car from here.The battery is the soule source of electrical power for the car. The battery is changed during vehicle operation by the alternator. Corrosion is the battery cable’s worst enemy. If you open the hood of your car, you may find a white or bluish powder looking substance (dried acid) on the battery and cables. This acidic substance will corrode the battery terminal-ends and the battery cables. It is good practice to have the battery and cables checked and cleaned at regular intervals. Cost is depends on the type of car you drive.
Old 05-07-2015, 04:17 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
