doozer's Avatar
Red face Media blast my transmission
What is the best method to media blast a 930 tranny so it looks like fresh aluminum, but will not dammage the tranny case??
Any photos??
Todd
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 02-10-2005, 01:03 PM
Me like track days
Craig 930 RS's Avatar
No!
Have it cleaned in a cabinet washer - it will looks great -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-10-2005, 01:19 PM
doozer's Avatar
I found these from a bost by Britain Smith on Bead Blasting
This is what I want it to look like then I am going to coat it with GlistenPC by Por-15
Todd
Old 02-10-2005, 01:30 PM
Me like track days
Oh, a removal and coat the whole trans deal. Ok.
Old 02-10-2005, 01:34 PM
doozer's Avatar
Is there a reason not to do this?
Todd
Old 02-10-2005, 01:36 PM
doozer's Avatar
This is what I am going to coat it with:
Primer, Paints, & Coatings » CLEARCOATS »
_
GLISTEN PC
A Brilliant Two-Component Clear Coating
GLISTEN PC is a High Gloss, Rock Hard, Water-clear topcoat designed for spray or brush application over all metal surfaces, including highly polished aluminum and chrome surfaces. GLISTEN PC will not leave brushmarks, and will dry in less than one hour, but will take 3-4 days to reach maximum hardness.
When GLISTEN PC is first dry to the touch, it will appear to be very soft. Avoid touching it for several days until it becomes hard and tough. Accidental contact could damage the surface before full cure has taken place. Like many other coatings, GLISTEN PC is a MOISTURE-CURED coating, which means it is strengthened by exposure to moisture. It will never crack, chip, peel, or yellow, and is very flexible as well.
Todd
Old 02-10-2005, 01:40 PM
Me like track days
What about the fasteners etc all receiving this coating - effectively sealing the whole thing & making a PITA when the trans will need to be opened? Just a thought.
Old 02-10-2005, 01:42 PM
doozer's Avatar
It will be done while it is apart
Todd
Old 02-10-2005, 01:43 PM
doozer's Avatar
Todd
Old 02-10-2005, 01:44 PM
Me like track days
Then why not?
I'd be leery of the bolt seating surfaces -
