964 radio removal?
how does one go about pulling the in-dash radio/cd unit? thanks in advance.
2000 Boxster Tiptronic 2005 Ducati M1000S |
Do a search on Ebay motors.
"Porsche radio tool" You need to locate or buy one of those tools.
Current Rides: 1999 Carrera |
are those the flat ones then?
like these:
2000 Boxster Tiptronic 2005 Ducati M1000S Last edited by raleigh5; 02-08-2005 at 07:55 AM.. |
You don't need a special tool to remove the Porsche cd-2 radio.
Remove the plastic trim around the radio, it should come off easily. Once the trim is remove you will see how the radio is held in the steel chassis. You will need to move the two pins to the center position and then pull the radio out. |
Gotta be very careful about the dash around the cd player and besides it's not as easy as ruf-porsche says it is
got it.....not "Gone in 60 Seconds" ....but it is out. thank you guys!
Hope you have the radio code because once you disconnect the radio, you will need the code in order for it to work again, but you already knew that! If you are going to install a new radio in place of the cd-2 and plan on cutting the old harness, I would like to buy the old harness from you. Some low life rip the radio out of my car and cut the harness. I have installed a new radio, but had to make a temporary connection in order to get the radio to work again Last edited by ruf-porsche; 02-08-2005 at 03:32 PM.. |
