Unhappy 915 transmission shift problem
When shifting into reverse sometimes nothing happens, its like the shifter is in neutral, I have to go into first gear and then back into reverse so that it will engage.
Any help on why this happens is appreciated.
Old 02-09-2005, 11:32 AM
normal. reverse is not syncronized, and often the gears that need to mesh together, meet tooth to tooth when you try to engage them, rather than tooth to notch. (one gear slides sideways into the other gear, and they're straight cut gears). so you have to either let the car roll an inch or so, or let the cluch out for a moment to rotate the shaft and try again.
206 637 4071
Old 02-09-2005, 11:36 AM
Saying that's the problem would replacing the syncro fix the prolem.
Old 02-09-2005, 12:28 PM
Driving member
jester911's Avatar
There is no syncro to replace for reverse. That is what John is saying. So it is just a trait of this tranny.
Sometimes it actually works better to shiift into 1st and then to reverse.
It is just a quirky tranny.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 02-09-2005, 12:48 PM
