v9ff's Avatar
'84 911 will crank but doesn't start right away
I have a 1984 euro 911 and anytime I try to start the 911 it takes several attempts to start it before it turns over and runs. Sometimes I end up cranking it for 5-10 seconds before it will start and that takes 3-4 tries. Eventually, it does start but it's painful to my gut.
Recently, I've updated my battery to a small Odyssey battery and just replaced the fuel pump last week. Could the battery be the issue? I don't think so because I had the problem even before the battery change.
HELP!
Old 02-10-2005, 08:28 AM
Still Doin Time
asphaltgambler's Avatar
Does it crank but not fire or when you turn the key nothing happens? I'm unclear from your posting
Old 02-10-2005, 08:48 AM
v9ff's Avatar
Yep... it cranks but does not fire up. It takes me several attempts before it will start.
Old 02-10-2005, 08:49 AM
addictionMS's Avatar
bet it is loss of fuel pressure, there is a pressure valve at the pump, after the pump, and one on the return line at the rear of the motor, one may be bad. Easy to check next time before you start the car, undo the nut on the drivers fuel rail, slowly and see if you have residual fuel pressue, if not , that is the problem. The 3.2 fuel pump only starts running after the motor is turning over, so if you loose the residual pressure, it takes time to build it up again. Thus you need to turn it over a few times to get it going. Mine is that way, I live with it. Should fix it, someday after everything else is done.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 02-10-2005, 09:04 AM
v9ff's Avatar
Cool! I'll check it out.
Are there any other potential problems that I can check out that may cause my issue?
Old 02-10-2005, 09:15 AM
Fuel pressure regulator ( on one side of the engine) and fuel pressure damper ( on the other side) can be bad and lead to apparent low fuel presuure restart problems.....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-10-2005, 09:32 AM
3.2 CAB's Avatar
Ditto on what Will said. fuel pressure reg.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 02-12-2005, 09:04 AM
