-   -   Animated 911 engine - the x-ray version (http://forums.pelicanparts.com/porsche-911-technical-forum/205740-animated-911-engine-x-ray-version.html)
DarrylD 02-10-2005 11:26 AM
I think this turned-out pretty cool... looks like x-ray vision!
http://members.aol.com/darryld/930xray.gif
Makes a particularly stunning desktop if you set your border color to black as well.
island911 02-10-2005 11:33 AM
Cool.
Now change the spark back to blue, and add a toroidal swirlling flame-ball, for the powerstroke.
Oh, and I want this on my desktop before you leave today. ;)
DarrylD 02-10-2005 11:37 AM
Here's a thought, liberally apply ChapStik and ..... :)
randywebb 02-10-2005 12:46 PM
I like the yellow rather than blue spark...
82SC 02-10-2005 01:43 PM
that is sweet
how about changing the throttle plate position and make the engine rev faster
like a sine curve...an engine revving...
also how about maybe a 1/2 real time speed or a real time speed to show how crazy internal combustion engines really are...
different color for incoming...combusted...out going air
oil sloshing around the case...
yeah make it so the viewer can move a slider and change the revs...
hahaha...after I congrats you I give you more work
MJ
Jim Garfield 02-10-2005 02:10 PM
Keep up the good work, these are great. Now get busy with that see through 917 engine ........top view please. ;)
Teutonics 02-10-2005 02:20 PM
Oooooh, top view would be COOL!
cmonref 02-10-2005 04:43 PM
Darryl,
You do absolutely terrific work! Thanks from all of us.
But -- I hate to say this -- this version (and the other high-res version) have a glitch where, at the bottom of the power stroke on the left piston, the animation jumps forward and then resumes normal speed. Both of my computers display this behavior. It's like you left out a frame or two ... (if I correctly assume that this animation is the sequence of 20 frames).
Does anyone else see this?
DarrylD 02-10-2005 05:35 PM
Hey Brian, I don't see any problem with the version I'm currently hosting on my AOL account. I have no idea what's the problem, other than the crank counter-weight swings around at that point in the stroke, perhaps it's just an optical illusion?
I just so happen to have a 2D top view of a 917 engine in a book I own... I'll think about it! I was actually thinking about doing a radial Pratt & Whitney airplane engine first though!
As far as varying the speed (on the fly no less!) .GIF files refresh is an operating system feature, you'll need to take that up with Microsoft or Apple!
imcarthur 02-10-2005 06:52 PM
On my IE, on the Pelican thread, it works pretty slow & does have a stutter. If I save it & run it in IrFanView, it runs at hyperspeed. My Gif Animator runs it at a third speed, but witha stutter too.
Just FYI
Still really cool.
Ian
MotoSook 02-10-2005 06:59 PM
Darryl, that is COOL! Can I use it on my web site?
Driver Ed 02-10-2005 07:15 PM
Yep, it's cool indeed. From having stared at it too long, though, I can pick a nit -- there are just a few misplaced pixels within the top cooling fins of the right cylinder and one just above the left one.
Either that or I need to clean my glasses... ;)
BernieP 02-10-2005 07:59 PM
Holy crap that's great work! Thanks for a great screen saver. I don't even want to know what you had to do to learn how to do this.
Again Thanks!
Bernie P.
DarrylD 02-10-2005 09:06 PM
Hey Drivers Ed, great eyesight, look again! A fresh build of both versions just to clear up some garbage pixels and make sure all 20 frames are indeed intact.
Thanks again for the feedback!
masraum 02-10-2005 09:15 PM
Darryl, using Jasc Animation 3.0 (or whatever the current version is) allows you to set the delay of each frame. Maybe I misunderstood what you were saying. That's how I created the pause of the tach needle in my avatar. I just set the delay of certain frames to be longer than others.
DarrylD 02-10-2005 09:20 PM
Sure any .gif editor will allow a hard-coded value for each frame delay, what's being asked for is a user input variable frame delay.
randywebb 02-10-2005 09:36 PM
Any way to put a tach on it, even if the speed can't be changed?
Also, blue for fuel; red for exhaust, yellow for spark?
cmonref 02-11-2005 05:02 AM
<<Hey Brian, I don't see any problem with the version I'm currently hosting on my AOL account. I have no idea what's the problem, other than the crank counter-weight swings around at that point in the stroke, perhaps it's just an optical illusion?>>
Darryl,
Definitely not an optical illusion. Running independently, it runs smoothly and at the same speed as your earlier versions. Set as the desktop background and it slows down significantly and displays hery-jerky motion (earlier versions run fine as background). Then, playing some more, it became apparent that when it was the background, the whole display was slower, like clicking thru the Control Panel and Windows Explorer windows. Strange effect, limited to the high-res versions.
I'l just use the earlier versions on the desktop, but hate to lose the higher-res picture.
Thanks AGAIN!
Argeo 02-11-2005 06:25 AM
I must be the only moron who can't get this thing to work. .
That's what I get for thinking computers were a passing phase in the late eighties.
juanbenae 02-11-2005 07:57 AM
how about showing the chain tensioners, ramps and chain to cam on one side? it is my desk top so i still enjoy it as is. thanks DD
DarrylD 02-11-2005 09:30 AM
Hey Brian! The funny thing about the high resolution version is that it's about half the file size of the smaller, uncompressed one you're not having problems with.
I was thinking it may have something to do with a size limit on the .GIF processing software on your PC. The refresh rate between frames is set at 1/100 of a second, the shortest time available so the speed you see it is actually dependent on your PC's graphics card processor speed and the software that loads the .GIF file frames to it. Now I'm thinking it's a buffer size limit on your PC because that would truncate the file as it's loaded into memory. That would explain the high number of pixels version vs. large file size version acting different.
Sorry I didn't reply Souk, sure copy the .gif file anywhere you want. My only issue is with somebody modifying the file itself.
MotoSook 02-12-2005 06:29 AM
Darry, thanks. I'll give proper credit, and I don't have the talent to modify it :( :)
austin552 02-12-2005 09:21 AM
Where's the 3-D version? Got my glasses ready. :cool:
