73911guy's Avatar
Anybody running Bridgestone S-03's on a 69 - 73 911 with 6x16 wheels all around?
Now that I've spent all winter collecting 6x16 wheels and the 205/55/16 Bridgestone S-03 tires that arrived yesterday look VERY wide, I'll ask the question....anybody running this combination? I've got 21/27 torsion bars and 22 sways all around, car is set at "Euro" specs. Everything Looks like it will fit when I measure it but I'm getting a bit worried - tires are scheduled to be installed Saturday. Can anybody relieve my fears that the tires will rub, particularly in the rear?
Jim
Old 02-09-2005, 05:43 PM
205/50 16 will fit I am not sure about the 55 series
Michael
Old 02-09-2005, 05:57 PM
tangerine911e's Avatar
Jim,
205/55/16 should be not problem on the rear, but all the early cars are all a little different - only way you can tell will be to fit them on the car. With the 205s up front some have commented they are pretty close - rolled fenders may be needed to stop rub at full lock (bit then again, who goes fast on full lock!!!).
I'm running 205/55/16 on the front - no clearance problems at all. I've got 225/50/16 on the rear, but yet to run them seriously (only at 'normal' speed - no rubbing), although the car will have 30mm hollow bars in the rear and a little more camber before venturing out in earnest.
Ash
'70 911E tangerine coupe (Ash's car)
'71 911T viper green targa (Trac's car) - Sold
Old 02-09-2005, 06:38 PM
73911guy's Avatar
Thanks for the replies - anybody else?
Jim
Old 02-10-2005, 05:17 AM
Cornpanzer's Avatar
I run 205-55/16 (16x6 Fuchs) Yokos on my 70"S".
Never had any probs.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 02-10-2005, 05:43 AM
IROC's Avatar
These should fit with no problems. 205/55s on 7x16s usually even fit OK in the rear.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-10-2005, 06:15 AM
I run 6x16 x4 & 205/55/16 x4 with S-03's
S-03's raised the car up about 1/4"over similar sized RE-71's, no clearance prob on 25.5" & 25".
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-10-2005, 10:56 AM
cornpanzer,
sweet ride whats in the rear.
Michael
Old 02-10-2005, 01:58 PM
73911guy's Avatar
Thanks for the responses. We'll see how things go on Saturday!
Jim
Old 02-10-2005, 05:36 PM
Cornpanzer's Avatar
Originally posted by Walko
cornpanzer,
Michael
Thanks!
Stock 2.2 S = funand reliable
1970 911S,
RGruppe#252
Old 02-10-2005, 07:18 PM
Sounds good
Michael
Old 02-10-2005, 08:09 PM
