LinkBack | Thread Tools |
Anybody running Bridgestone S-03's on a 69 - 73 911 with 6x16 wheels all around?
Now that I've spent all winter collecting 6x16 wheels and the 205/55/16 Bridgestone S-03 tires that arrived yesterday look VERY wide, I'll ask the question....anybody running this combination? I've got 21/27 torsion bars and 22 sways all around, car is set at "Euro" specs. Everything Looks like it will fit when I measure it but I'm getting a bit worried - tires are scheduled to be installed Saturday. Can anybody relieve my fears that the tires will rub, particularly in the rear?
Thanks Jim |
205/50 16 will fit I am not sure about the 55 series
Michael |
Jim,
205/55/16 should be not problem on the rear, but all the early cars are all a little different - only way you can tell will be to fit them on the car. With the 205s up front some have commented they are pretty close - rolled fenders may be needed to stop rub at full lock (bit then again, who goes fast on full lock!!!). I'm running 205/55/16 on the front - no clearance problems at all. I've got 225/50/16 on the rear, but yet to run them seriously (only at 'normal' speed - no rubbing), although the car will have 30mm hollow bars in the rear and a little more camber before venturing out in earnest. Ash
'70 911E tangerine coupe (Ash's car) '71 911T viper green targa (Trac's car) - Sold |
Thanks for the replies - anybody else?
Jim |
I run 205-55/16 (16x6 Fuchs) Yokos on my 70"S".
Never had any probs.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/ 1970 911S, 10 sec 67 Beetle (300 rear wheel HP) RGruppe#252 |
These should fit with no problems. 205/55s on 7x16s usually even fit OK in the rear.
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I run 6x16 x4 & 205/55/16 x4 with S-03's
S-03's raised the car up about 1/4"over similar sized RE-71's, no clearance prob on 25.5" & 25".
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
cornpanzer,
sweet ride whats in the rear. Michael |
Thanks for the responses. We'll see how things go on Saturday!
Jim |
Stock 2.2 S = funand reliable
Sounds good
Michael |
