-   -   DashTop™ dash "caps" are not bad! (http://forums.pelicanparts.com/porsche-911-technical-forum/205922-dashtop-dash-caps-not-bad.html)
MikeSid 03-09-2005 01:00 PM
"competent reupholstry" probably wouldn't be me doing it in my garage. But I think I may give this a shot.
Wrecked944 03-09-2005 01:30 PM
Dave, that is supreme. Thanks for sharing the pics and info. Don't be surprised if the day comes soon when you can spot a Pelican car by the ultrasuede on the dash cap. :D
MikeSid 03-09-2005 01:42 PM
Yellowbird RS 03-09-2005 05:10 PM
update on my hairliner
http://forums.pelicanparts.com/uploa...1110420553.jpg
http://forums.pelicanparts.com/uploa...1110420569.jpg
tomorow the dash & door arm rest ;)
doozer 03-09-2005 05:25 PM
So when you were done were you tempted to lay on your back in your seat and walk barefoot on your headliner - I would have been :D
That looks GREAT!
smestas 03-09-2005 08:11 PM
Wow! Headliners also. Looks awesome YellowBird.
We need to move these posts and make a "ultrasuede" thread.
}{arlequin 03-09-2005 11:51 PM
Maybe just a general "pimpin' my ride" thread :D
yello-bird, that looks great. Makes my dash job look like a spark plug job compared to a 915 rebuild ;)
Deschodt 03-10-2005 05:34 AM
Pimpin' ? The 997 has an alcantara headliner ;-) And it's the car's best feature too ! I am all for this ! Did you make the headliner by stitching pieces together ? Template ?
This is all very cool. Maybe I should fix my temps gauge first but I like this thread !
Yellowbird RS 03-14-2005 12:56 PM
an up-date
http://forums.pelicanparts.com/uploa...1110837029.jpg
http://forums.pelicanparts.com/uploa...1110837069.jpg
http://forums.pelicanparts.com/uploa...1110837107.jpg
http://forums.pelicanparts.com/uploa...1110837205.jpg
http://forums.pelicanparts.com/uploa...1110837226.jpg
http://forums.pelicanparts.com/uploa...1110837271.jpg
http://forums.pelicanparts.com/uploa...1110837345.jpg http://forums.pelicanparts.com/uploa...1110837376.jpg
}{arlequin 03-14-2005 01:00 PM
Wow, color-coded stitiching??? Now that's stylin' :D
Looks great. Did you do it yourself? Nice job! Very even stitiching. Guess that was a way to go for me too, but after I finished re-covering my seats I quickly returned the sewing machine back to the store :D
scottb 03-14-2005 01:03 PM
I'm impressed with the workmanship!
Let me ask the collective, though. Is the contrast between the vinyl on the dash and the ultrasuede too stark? Like them or not, the Dash Cap sort of blends in with the factory dash. Once upholstered with ultrasuede, the contrast is obvious.
Thoughts?
}{arlequin 03-14-2005 01:11 PM
It's a bit darker under the dash, so the un-upholstered part isn't as glaring, and besides, my dash top, and every one elses, was smooth (leather I think... maybe vinyl) while my dash panel is basketweave. I don't think anyone ever thought that they don't match even though the texture is different.
I haven't gotten around to it but I will post some pics later. In my opinion, the difference "disappears" and isn't noticeable.
Biff 04-13-2005 04:33 PM
Could this whole procedure be done with a good quality full grain leather, it might look better than original that way? Biff
techweenie 04-13-2005 04:47 PM
I've seen recovers done with the vinyl that has the *exact* grain cast into the factory dash. So it's definitely out there.
As a veteran of several 'dash top' coverup installs, I have to warn that they will warp badly over time. And if you use the silicone adhesive inconsistently, the shell will expand where it's *not* stuck down, making the warping potentially ugly. but at 1/10th the cost of a new dash (uninstalled) maybe replacing the dash cap can be considered maintenance.
Biff 04-13-2005 05:47 PM
I re-roofed a flat rubber roof section of my home last fall and used some really strong industrial contact adhesive. If that stuff can take direct sun year after year for 20-30 years I would think it could hold down a piece of vinyl or leather for a while. What do you think? Biff
techweenie 04-13-2005 06:22 PM
Biff, use a lot of it, uniformly under the entire area, and I bet it'll essentially be permanent.
Deschodt 04-14-2005 05:32 AM
I've gotten a dash top following this post and I gotta say the fit is impressive ! In seconds my car went to multiple cracks dash to smooth ! it's not the same material, it's a toupee alright, but I kinda like it ! The only thing - not reported above - is the fit is so-so where the air vents are. You have to remove the plastic air vent covers fo ra good fit and then you have those ugly metal slats visible... But overall, for $80, I'd recommend one !
}{arlequin 06-09-2005 10:36 PM
"appearance update"
http://forums.pelicanparts.com/uploa...1118384902.jpg
http://forums.pelicanparts.com/uploa...1118385000.jpg
http://forums.pelicanparts.com/uploa...1118385192.jpg
89turbocabmike 06-09-2005 10:57 PM
Looks like it's holding up well Dave:)
smestas 06-09-2005 11:39 PM
MMMMMMMMMMMMMmmmmmmmmmmmm..............
Me likes that dash alot }{arlequin!!
}{arlequin 06-10-2005 05:32 AM
it does tend to hold onto the dust, not sure if it's a good thing or bad
looks worse in pics than before b/c I just had an excursion through grass/dirt this past weekend so some more crap flew in through the windows
I think a blast of computer-cleaning air will clear it nicely ;)
Tinker 06-10-2005 09:57 PM
Dave,
No problems with the perforations or seams from the speaker grill showing up?
I have been thinking about this ever since I rode in my buddies 996 with a similar/same material on the dash.
Tinker
}{arlequin 06-12-2005 08:47 PM
Tinker,
My "real" dash was in such bad shape that the PO put a plastic dash-shaped cover over it. I recovered that cover. It didn't have the speaker grill nor seams. I am pretty sure they would show through if you did this.
BrokeMyCar 03-08-2006 09:12 AM
... so it's been about a year ... how are these awesome-lookin' dashes holding up? Any lessons learnt with time?
Gotta say, this thread makes me want to abandon my "get my brakes to work" project and focus on the interior. =)
Babak
lateapex911 06-29-2006 10:53 AM
Wow, cool stuff. Dave....I'd love to see it in person. How do the edges, where the cover and the original car look?
And Yellowbird, I am very impressed with the stithing. Did you do that yourself? Mahine stithed I assume. Was it stitched before the material was installed on the dash? Impressive that the stitching lines up so well. And was yours on the dash or on a cover?
Thanks!
