Carrera Sled's Avatar
Seat recline motor
The power seat-back adjustment no longer moves in the forward direction on my '85. The other 5 adjustment directions work fine. I searched the forum for this kind of problem, and came up with mainly power switch issues. Has anyone seen problems with the motor? How is the recline motor accessed? I'll put the multimeter to the switch, etc. this weekend. Thanks!
'85 Carrera Coupe, White Gold Metallic - 8" rear Fuchs, Fittipaldi steering wheel, Weltmeister short shift, Turbo tie rods.
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower." - Mark Donohue
Old 02-10-2005, 10:53 PM
Re: Seat recline motor
Originally posted by Carrera Sled
The power seat-back adjustment no longer moves in the forward direction on my '85. ... I'll put the multimeter to the switch, etc. this weekend. Thanks!
That's what I'd do first...test the switch. I had a similar problem with the seat up/down switch. At first I only tested it with a 12v lamp tester...in the down position the lamp lit brightly...in the up position the test lamp was much dimmer and so the seat motor would not even turn in the up direction. So either cleaning the switch or replacing it will probably do the trick. You can probably swap out the wires from one motor to another just to make sure it's the switch. Just don't drop $160.00 on a new seat motor until you know for sure...unless of course you want to start a collection of expensive and unneeded parts like I did.
-Steve
'87 Carrera Targa
Old 02-10-2005, 11:14 PM
MAGA
Tim Hancock's Avatar
Switch contacts needed cleaning in two sets of mine. Be careful that when you take them apart so that you don't loose any pcs and remember how they go back together.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 02-11-2005, 04:22 AM
Ben,
The way I once accesed the motors was by removing the seat. It's not a difficult task. There are 3 allen type bolts on each rail, one on the front and two on the back. By sliding the seat all the way forward or all the way back they are easily accesed.
Max.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 02-11-2005, 08:46 AM
Originally posted by maxhofer
Ben,
Max.
Max is right. I'd also add that as you remove the allen bolts, slip a finger inside the rail and under the rectangular nut thing so it doesn't drop inside the rail. If you don't you might need some needlenose plyers to retrieve it. After the bolts are out you can tip the seat back to access and unplug the wires. The Bentley book explains all this BTW. Good luck.
-Steve
'87 Carrera Targa
Old 02-11-2005, 11:17 AM
Virginia Rocks!
VaSteve's Avatar
Please post your results. It's on my list of things to do as well. If I ever get the motor back in.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-11-2005, 12:31 PM
it's almost always the switch.
206 637 4071
Old 02-11-2005, 12:33 PM
Thanks for the input, guys. I'll post what I find with the switch troubleshooting; hopefully it's just cleaning the contacts.
I WILL be careful during the switch disassembly... When removing the engine/transaxle for a clutch replacement, while pulling the main electrical connector for the engine, the engine side backshell popped off, along with all the wires! After a few expletives, and a cold neck oil (Coors Light, I believe) I was able to place the wires back in the shell with pretty good confidence on the pin locations just by the "set" the wires had taken in the shell. It ran fine... whew!
Old 02-11-2005, 05:55 PM
