teamgomez's Avatar
Siezed Turbo Tie rods- help!
'87 carrera w/ cheap a$$ turbo tie rods (rubber is all deteriorated) are causing fits- I have new ones ready to install but cannot remove the old ones. Car is on jacks, and I'm underneath it trying to break them free from the steering rack. Have already used WD40 (no Kroil on hand) and bent a craftsment 16mm wrench.
Any ideas? Would love to get the new ones on tonight! Thanks-
2004 GT3
1969 Camaro 502 ZZ BBC
1980 Weissach 911- gone to a good home in Colorado
Old 02-11-2005, 01:32 PM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
If they were installed with Loctite Red (or any high strength thread locker), they will require heat to remove. I've broken a 14mm socket and wrench (Craftsman) trying to remove a nut that was secured with Loctite Red. A little heat from a torch melted the bond and the nut came off easily.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 02-11-2005, 01:50 PM
teamgomez's Avatar
hmmmm...wonder how much heat I could apply in that area b/f the fuel tank started 'to get a little upset'....
2004 GT3
Old 02-11-2005, 02:13 PM
Team California
speeder's Avatar
Wow, these should not have been Loctite'ed in the first place, it is not a fitting that ever comes loose(?)
Denis
Old 02-11-2005, 02:27 PM
"Wow, these should not have been Loctite'ed in the first place, it is not a fitting that ever comes loose(?)"
Not what our host states in "101 Projects." Page 152, second paragraph down - "Before you screw the tie rod into the rack, make sure that you spread a few drops of Loctite on the threads."
Regards,
Jim
'86 Carrera Coupe
Old 02-11-2005, 02:56 PM
i loctite them.
206 637 4071
Old 02-11-2005, 03:24 PM
I believe there is a lock nut at the screw-in end that needs to be removed. Once this is accomplished, you may be ok in getting the rod off. Good luck.
85 Coupe
Old 02-11-2005, 03:46 PM
stormcrow's Avatar
Take a sawzall and cut them off or split the nut with a nut splitter.
"A Porsche does more then just go fast in a straight line"
SteveKJR
Proud Owner of a 78 911 SC Targa
Old 02-11-2005, 03:47 PM
Zeke's Avatar
Are you thinking of the strut end? Did you read the question? How would one accomplish anything by cutting them off? It would be hell to remove the piece from the rack if it was a stub, don't you think?
AFA the jam nut goes, before you bend or break anymore wrenches, try a cold chisel on the end of the flats on the nut. The sharp blows will help, but they won't help the steering box any. So be judicious with the amount of hammering. By way of suggestion, I would turn the steering so that the minimum shaft extends from the housing and you can still get to the nut.
One source of heat that you may use with some safety is a heat gun rather than a flame. Every little bit helps.
Old 02-11-2005, 04:05 PM
teamgomez's Avatar
Thanks a bunch for all the tips, guys. This helps- will post results.
2004 GT3
Old 02-11-2005, 05:16 PM
Elombard's Avatar
Hey I want to buy these chepies from you if you get them off in one piece, I want to do an experiment.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 02-11-2005, 06:41 PM
teamgomez's Avatar
They're off, guys! Thanks for the help- sorry to say that they're not in one piece anymore, tho..the heat did the trick!
2004 GT3
Old 02-12-2005, 05:18 PM
