Which Platinum Plugs for SC
I’d like to put Bosch platinum sparkplugs in my 78SC. I’ve seen recommendations of every number from WR5DP through to WR8DP. Does anyone know what the right plug is? Please include the source of your information. Thanks.
Old 02-12-2005, 12:38 PM
Jeff Alton's Avatar
Why do you want to put platinum plugs in your car? Do a search and save a little money!
Cheers, Jeff
www.turn3autosport.com
Old 02-12-2005, 12:50 PM
yea, I am in agreement with catca, everything I have read has led me to believe they are not in your cars best interest.
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 02-12-2005, 01:44 PM
GeorgeM's Avatar
The Bosch website says W8DC in Bosch Super.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
wastintime's Avatar
Send a message via AIM to wastintime
yeah, platinum isn't that great for NA porsches... or even turbos. We use Bosch super for NA, and silvers for turbos
-Andy
'67 912, '92 C2, and '93 RSA - all gone
Old 02-12-2005, 01:46 PM
My "two cents" worth, stay away from platinum (and other exotic) materials and stick with proven, reliable copper core plugs. Bosch, NGK...even AC Delco or Autolite. I can't think of one auto application I have personally experienced where I was better off with platinum over a standard copper plug.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 02-12-2005, 03:13 PM
Jeff Alton's Avatar
I use NGK or bosch is a customer insists.
Old 02-12-2005, 03:27 PM
Chris Lovell's Avatar
I replaced copper Boschs with twin electrode platinum. No postive difference. Copper going back in next time.
CWL
'86 Carrera Coupe
'88 Carrera Cab
'02 525i Sedan
Old 02-12-2005, 03:40 PM
blue82coupe's Avatar
I would stay with Bosch.Copper W5DC. Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 02-12-2005, 05:52 PM
I used split platinums for a long time. Left them in longer than I should have between changes. They came out looking perfect, excepting the normal deposits that form. The NGK coppers I put in perform the same as the platinums.
'80 SC
Old 02-12-2005, 06:21 PM
I started running platinums almost 20 years ago, long lasting and no performance problems.
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 02-12-2005, 07:05 PM
Now in 993 land ...
aigel's Avatar
It never hurts to go with what the car came with from the factory. This is true for the 911 and every other car I every had.
Don't diss platinum for the cars that came with them from the factory. My wife's truck has platinum plugs. They are a 100k mile service item. And they work great. You want them in there that long, because you have to be a proctologist to change them.
George
81 SC (sold)
Old 02-12-2005, 07:16 PM
Jeff Alton's Avatar
I have no problem with platinim plugs. I just do not see a need for them in a 911 engine, thats all.
Jeff
Old 02-12-2005, 08:45 PM
Jeff
Not among the bigger expenses on these cars, but they do cost less than several sets of other plugs. They haven't fouled on me like the original plugs.
Charlie Baer
Old 02-12-2005, 08:54 PM
Jeff Alton's Avatar
Well if the plugs foul it usually is not the plugs fault, provided it is the correct heat range. They just aren't required. Take it with a grain of salt though, I am the king of things that aren't required, like coil overs. 3.6 light weight body work etc..!!!!! They are not bad products. I used to use them, but found no performance or lifespan gain, so I stopped. I can get hem pretty darn cheap here too. Don't get me wrong, if you use them and they work for you, you should keep useing them, infact it may be unwise to switch to something different.
Cheers, Jeff
Old 02-12-2005, 09:14 PM
gerard vaglio's Avatar
I don't want to sound like I'm name dropping but I once took a class with Bruce Anderson and this topic came up.
At the time he was talking about sc's and earlier cars and said NOT to use the platinum plugs. He felt they were overpriced, didn't perform as well as copper and didn't hold their gap as well as copper.
To which I said "...well, what about my cool collar."
Old 02-12-2005, 11:18 PM
Sadly, this post has been highjacked into a factless ramble about personnal preferences. To those that named a plug, thanks. To the others, sorry I asked!
Old 02-13-2005, 07:23 AM
Unregistered
sammyg2's Avatar
you could always delete the thread
Old 02-13-2005, 08:02 AM
Jeff Alton's Avatar
Sorry for trying to help you out...
Old 02-13-2005, 08:26 AM
I wouldn't say it's a factless ramble. This forum relates how this, that, or the other thing worked or didn't work for various individuals. In general you're hearing that platinums seemed to work okay but probably aren't necessary, as the coppers worked just fine too and are less expensive.
'80 SC
Old 02-13-2005, 05:58 PM
