-   -   Help - inserting new squeegee in window trim (http://forums.pelicanparts.com/porsche-911-technical-forum/206286-help-inserting-new-squeegee-window-trim.html)
dgraves 02-13-2005 06:33 PM
Any helpful hints out there for inserting new squeegee rubber into the outside side window trim? This is the metal trim at the top of the door next to the window. My old squeegee falls right out while the new ones I can barely slide in 3 inches.
1976 911
Dan
cool5 02-13-2005 06:47 PM
Dan, try some dishwashing soap, worked for me
Matt
dhoward 02-13-2005 08:26 PM
Diluted dish soap. Even then it's REALLY tough. But when you're done you'll say, "THAT was a load of bull***** for not very much gain."
Happy Porsche-ing!
SmileWavy
DavidI 02-14-2005 03:22 AM
Dish soap like others have said. You have to push and pull it firmly, but not so hard as to tear it.
Good luck, David
barlowdo 02-15-2005 09:19 AM
I just put one side up against the extruded aluminum channel and poked the other side in with a screw driver.
Seemed to work for me.
-Don B
