What's the spark glug gap for NGK BP7ES?
I did a search on the board, and couldn't find a consensus on the gap of NGK BP7ES.
Thanks |
Depends on what ignition system you are running, but in your case I would start with the factory recommendation of .028
factory CDI,
Ok I'll go with .028, Thanks. |
I gapped mine at 7mm. As per NGK spec.
NGK spec=.028 stock
w/MSD= .034 |
| All times are GMT -8. The time now is 10:49 AM. |
