There has been a lot of interest on this board concerning the replacement of the stock 911 fuse panel with the newer "flat" fuses. The biggest problem being availabity. THE WAIT IS OVER!
I received an Eastwood catalog (Dec. 2003) today that has an 18 fuse block advertised. It is a straight line design and comes pre-assembled so you don't even have to make a base. It is Eastwood part number 60090 on page 8. That's the good news. The bad news is that it sells for $154.99 (less 10% thru 12/31). So now you have a choice. Buy the fuse holders from Norway and build a base for about $30.00 or drop the big bucks for the prefabricated unit. Either way, you will have a better electrical system than stock. Good Luck! Fred Cook '80 911SC coupe (with flat fuses)
911 driver
Ove '77 911S targa |
Does it come with a cover of some sort? Also, since it has what appears to be different dimensions, the boot carpet will have to be modified.
1984 Targa |
several of the stock fuse terminals are bridged in the back. like 3 in a row, 2 in a row. does the eastwood one come bridged, or is it bridgeable? i don't think so. it would probably have to be bridged with short wire loops, which isn't best.
The fuse panel strips in the Eastwood catalog appear to have individual in and out terminals which is most like the stock fuse blocks. While it is true that the stock blocks are jumpered on the back, it is not only possible to provide the same jumper pattern externally, but has been done. It is not difficult, but does require a fair amount of patience and perfectionist attitude to do properly and neatly. One thing to keep in mind is that even if you split the evaporator fan and front condenser fan to separate fuses, you will still need a 20 amp fuse for the evaporator fan and seven or eight other positions. Because of the load capacity, most of the 5 or 6 gang fuse holders won't work because they are only rated at 15 amps capacity. One of the reasons that I used the fuse holders sourced from Norway (thanks, Ove!) was that by using a base plate of my own design, I could still get the original cover back on the fuse/relay box. I believe that in the long run, the fact that the flat fuses have much more contact area on the lugs will reduce or eliminate the tendency of the old style round fuses to heat and corrode the contacts. I realise that this project is not for everyone, but like I said earlier, it can be done successfully and provide some electrical system peace of mind.
![]() Fred Cook '80 911SC coupe (the one with flat fuses) |
Cole-Hersee makes one with 18 fuse holders....#46377-18 sells for about $30.
Available through NAPA, etc. Bob
Bob Hutson |
The coleman-hersee 46377-18 has the common hot feed
Qarl |
Karl is correct..common hot feed.
But...if you need that....then it's OK. If you need to divide the feeds...just get multiple blocks. The dash number at the rear of the part number refers to the number of fuses on the block...all common fed. So...a 46377-10 is a 10 fuse block....etc. Bob
Bob Hutson |
If Eeastwood has it, so does someone else. And probably for less. There are few 'exclusives' in the mail order world.
Re: Flat Fuse Panel.....
Tim 1983 930 w/ goodies |
How about fashioning an adpater that would fit over/into the existing prongs and provide the flat fuse receptacle. Snap on, plug and play.
Warren & Ron, may you rest in Peace. |
1984 Targa |
For those who have upgraded their fuse box, how did you jumper between 2 terminals?
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
911 driver
Ah. Makes sense. Thanks for that Ove.
Does anyone know what the jumper situation is on an SC? By that I mean how many terminals are linked? I've found a place that supplies a fuse box with 21 terminals. The layout is 4 groups of 3 fuses jumpered together 3 groups of 2 fuses jumpered together 3 individual fuses Here's a link to their website. It's about halfway down the page. On a related note, I updated the rear 3 point fuse panel to blade fuses (somewhat messily) and my previously non working heated rear screen, rear wiper and heater blower now all work!
I just recently met a long lost cousin who works for way-tek. If I can get her some info on what we need, we might have a source.
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
