Lubing the engine lid release cable
What kind of grease/lube should I use to lube my engine lid release cable? The handle end of the cable is a bit rusty and not too smooth right now.
Thanks in advance.
-Steve
'87 Carrera Targa
Old 03-04-2005, 10:36 AM
Somatic Negative Optimist
Gunter's Avatar
I would try any light oil from both ends of the cable. Move the cable in and out several times for good penetration. Do the trunk-lid cable as well.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-04-2005, 11:03 AM
buster73's Avatar
I use a motorcycle "cable care kit" that allows to push the lubricant through the full length of the cable. Only ca. $15 and will last forever.
Regards,
Guenter
73.5 911T, mod
Old 03-04-2005, 11:54 AM
randywebb's Avatar
Guenter - can you tell us more about how it works?
Post a pic of what it looks like?
Sounds like something to add to my long-term maintenance thread...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-04-2005, 12:02 PM
Senior Member
Superman's Avatar
It's a fixture that clamps onto the end of the cable sheath. The cable itself exits the fixture also, but the fixture makes a seal. The fixture has a hole into which you insert one of those little red straws taht come taped to aerosol cans. So when you squirt the juice in, it has no place to go but down between the cable and the sheath. Any motorcycle guy can show you his. Fixture, that is.
Mocha 1978 911SC. "Coco"
Old 03-04-2005, 12:09 PM
chrisp's Avatar
They have something similar for bicycles available at bike shops and bike mailorder catalogs. I never thought of using one for this though. Great idea!!
'83 SC
Old 03-04-2005, 12:22 PM
loosen the screw at the latch and pull out the cable. easy now.
206 637 4071
Old 03-04-2005, 12:55 PM
I found the "cable care kit" on the net and this sounds like the ticket. Think I'll try it. Thanks for the great ideas.
-Steve
'87 Carrera Targa
Old 03-04-2005, 02:31 PM
buttjoint's Avatar
I found john walkers reply right above your post. Think I will try that!
Old 03-04-2005, 02:55 PM
buster73's Avatar
You attach the cable luber adaptor to one side of the cable. Then you pressurize the lubricant until it flows out of the other end of the cable.
Regards,
Guenter
73.5 911T, mod
Old 03-04-2005, 03:11 PM
