Send a message via AIM to mattr_914
New seats in an early car
I bought some 74 911 seats for my 67 912 and noticed they dont fit (duh). I didnt expect them to so Im in the process of making adapters. Has anyone else done this? Any tips on making the brackets? I was thinking some 8th inch aluminum drilled out to size. They're already in autocad if someone needs the drawings I came up with.
'73 914-4 with 2056
'67 912 with wet paint (SOLD)
'96 GTI VR6
Old 02-17-2005, 06:29 PM
RallyJon's Avatar
I'm doing the same thing now. Since the general recommendation is 1/8" steel, I'm not sure if 1/8" aluminum is strong enough. If you've done the math and determined it is, let me know--love to save 4-5 lbs that way.
993 · 911 · STI · S4 · rally car
Old 02-17-2005, 06:42 PM
I'll do the math tomorrow. Im an engineering student, so this will be fun
'73 914-4 with 2056
'96 GTI VR6
Old 02-17-2005, 06:56 PM
DavidI's Avatar
matt, the rails on your 67 912 (which is what I used to own) are wider than the ones on your seat. I think they were about 1/2 inch or so. You can buy them for about 75$ or spend about half an hour and $10 to make them yourself. I used a 1/8 inch steel plate to narrow the rails on the floorboard and it worked fine. I would be leery of using aluminum because if you are in an accident, I am not sure if it would keep your seats in place. I am no expert about the safety stuff though.
Again, it is very easy to make your own. Good luck, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 02-17-2005, 07:40 PM
pjv911's Avatar
Send a message via AIM to pjv911
look here
http://www.***************/ProductPage.aspx?pid=105575&name=Seat+Adapter+Kit&type=20
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 02-17-2005, 07:45 PM
Im NOT paying 150 bucks for 4 pieces of steel... I'll do it myself.
Im starting to think the aluminum is bad. I'll find some steel and go with that.
'73 914-4 with 2056
'96 GTI VR6
Old 02-17-2005, 10:12 PM
HarryD's Avatar
Many threads on this topic (include seat adapter as a search term). Be sure you have a plan to anchor your lap belt/shoulder harness as the mounting point on later cars is different.
Somewhere here is a thread that give the pertinent dimensions. Older (pre-73) seat rails are about 18" on center, the newer seats are 16" on center. This is one thread: RSL-Classic seats .
If you do not want to fab your own, try PEParts (www.peparts.com).
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-17-2005, 11:42 PM
