3.0L into a 74' conversion fuel line question
Guys,
I am in the process of putting the 77' C3 that I just rebuilt into my 74' Targa. I have a question on how to adapt the CIS return line on the engine which has a b-nut fitting on it to the body which has a hose clamp barb fitting. Any advice or sugestions would be appriciated. Thanks http://forums.pelicanparts.com/uploa...1108679163.jpg |
My only comment is that the return line is low pressure, so you can be pretty liberal in finding a solution.
When I installed a 3.2 into my '76, I cut off the factory "b-nut" fuel return fitting and simply used a barbed fitting to interface with my existing CIS return to the tank. I vote for being creative and not constraining yourself into using the b-nut if you don't want to. YMMV... Mike |
| All times are GMT -8. The time now is 09:54 AM. |
