86 911 Wasn't a whale tail standard?
I thought in a 1986 911 a whale tail was standard?
Nope
negative, standard on Turbo, but smaller Carrera tail was always an option.
"Coffee is for Closers" "Push the button Max!!!" |
Curious - why would you think that?!? (
$1392.00 option code 473
Eric |
It seems he is looking at a car to buy (check his other posts) he is looking a a whote Targa with a tail.
You best bet to find out if it was original is 1) check the option codes in the front trunk. The next 2 apply to my car (1987) not sure about older cars. 2) The 3rd brake light in a car with a tail standard in moutend up by the roof, where a non tail car has the 3rd brale light down by the deck area where the speaker grills are. 3) Car that had a factory tail have 2 shocks top hold open the engine lid, non tail cars have only one shock.
I was looking for the option codes and didn't see the sport group or spoiler one listed anywhere? I did for 84 & 85.
86 911 Cab. |
This time the car I am looking at is a low mileage cab. from a guy in the PCA, he has owned 9 Porsche's. A much much better car so far..........
86 911 Cab. |
Just found a complete option list for all 911's. What me to post it?
option 475 is Brake pads without asbestos
86 911 Cab. |
The next question is: Which tail?
Good luck in your quest. David Duffield |
1987 models with a factory installed tail had an exterior mounted light that was extended up/out form the body ('goose neck') for visibility purposes. That would mean a tail (carrera or turbo) mounted on 1987 coupes/targas with an interior third brake light (at the bottom of the window) was NOT factory installed. Someone please correct me if I'm wrong so I can be sure to keep this bit of trivia straight.
'96 Coupe - Arena Red |
I'm not sure about that. My '87 Coupe which came with factory tail had the 3rd brake light high up on the interior side of the rear window. My '87 Targa, also with factory tail, had the "gooseneck" 3rd brake light on the exterior, mounted on the lid just above the tail. Perhaps different for Coupes, Cabs and Targas?
Tom
Ain't life grand? |
I think the look of the either the duck or whale really sets the car off. so since this one doesn't have, are there any negatives to adding it? Besides it won't be original equipment.
86 911 Cab. |
Factory Turbo Look AKA (Super Sport) Code M491
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
1 It reduces the lift at the rear axle. 2 It provides more air for the engine which results in a cooler engine If you are going to add a tail which lots of people do, to keep #1 above balanced for the whole car you'll need to add a front chin spoiler. The spoilers on 911's should always be added in pairs to keep the balance of the car at speed. If you want a tail, add away!
Is it possible that early and late production numbered cars in one production year have characteristics similar to the older/newer model? Later models having some changes that will be incorporated into the next year's car.
Tony G 2000 Boxster S |
