Need help with power steering removal
Does anyone know how to remove the nut holding the power steering belt sprocket to the cam on a 964 engine?
thanks,
anthony
Old 02-18-2005, 01:41 AM
Not Quite Banned
Thomas Owen's Avatar
The bolt is torqued to 88 ft-lbs and requires a special tool (Spanner 9236) to hold the gear.
Be careful -
Thomas Owen
1972 911T
1972 911S
Old 02-18-2005, 03:51 AM
Another special tool required. Is there something I can use in its place?
thanks,
anthony
Old 02-18-2005, 06:56 AM
If the engine is off the car and the tranny is out, then you can lock the flywheel.
Old 02-18-2005, 01:13 PM
