'89 Speedster problem
Help! I have an '89 Speedster. When pulling the handle on the cable that releases the safety latches on the clam shell to put the top up, I ended up with just the T-handle in my hand. The pull (also known as the draw button in the Speedster Owner's Manual) broke off the cable and left me with the T-handle and a shaft approximately 3 inches long. Anyone with a speedster ever have this problem, or have a clue on how to fix it???? I'd appreciate any suggestions. Thanks, Rick Coleman
Old 01-03-2005, 01:37 PM
89 Speedy's Avatar
Re: '89 Speedster problem
Hey Rick, sorry to hear about the problem. I haven 't had the same problem but the mechanism certainly isn't as exacting as one would like. Be sure to check all the nuts and bolts on the clam shell frame as well. Should be any easy enough problem to fix but the parts are likely to be out of stock at your local dealer. Wonder if Pelican has 'em.
1989 911 Speedster
2006 Cayman S
No one ever said on their deathbed, "I should have been more practical."
Old 01-03-2005, 11:57 PM
Thanks Speedy- Took your advice and checked w/ my local dealer. The cable (including the cable sleeve, clamshell end and the pull shaft) is approximately a $40 item. None in stock, as expected, but there were 5 at the wherehouse!! The T handle screws on to the pull shaft, and the clamshell end is attached to the safety latches with 1-2 bolts. The parts guy looked in the book and suggested that the new cable is fed in from the clamshell end. Sounds like a piece of cake, but....from my experience what looks and sounds like a 1 hour job takes a full day with lots of #@%x? thrown in for good measure. They indicated I should have the part in 1-2 weeks. I'll let you know how the project goes. Rick
Old 01-04-2005, 02:37 PM
911pilot's Avatar
89 speedster clamshell pull cable
Rick,
Im getting ready to replace my cable also.
Let me know if you ran into any problems I can avoid when changing mine!
Thanks,
Jeff
Old 02-13-2005, 07:15 PM
Hi Jeff- I received my cable over a month ago and still haven't had time to install it. I did take a hard look at the situation and it seems to me that to install it one has to remove the interior carpet panel against that area. That is going to require removing the handle that locks the clamshell into place when raising or lowering the top, and I'm guessing that requires a special tool? When I raised the top recently (only the second time since I've owned the car that I drove it with the top up) I used a long pair of needle nose pliers to pull the cable end where it broke off from the T-handle stem. It's east to insert them into the hole if you snap the plastic circle out of the hole. Let me know of your progress as it seems that you are going to get your cable replaced before I do. Thanks, Rick
Old 02-14-2005, 12:31 PM
911pilot's Avatar
cable
Rick,
It's a deal, I'll let you know.
Jeff
PS................you havent replaced the carpeting yet have you?
Old 02-14-2005, 02:27 PM
KobaltBlau's Avatar
oh man, I wonder how long it'll take to deplete 5 units in stock at the warehouse!
Andy
Old 02-14-2005, 02:34 PM
Jeff- I haven't pulled the carpeted panel yet, as I need to figure out how to remove the handle (any suggestions from readers of this thread?). I'll bet it removes the same way a manual window crank handle comes off. The interior is original as it is a very low mileage car, but I don't see why the panel won't remove and re-install easily once the handle is off.
There appears to also be a screw near the back of the panel, and I'm sure it needs to be removed. Rick
Old 02-14-2005, 02:44 PM
Rick, I just had my replaced at Pristine Motorsports in Huntington Beach. Dick Thorpe the owner is an absolute expert on the 1989 Speedsters. Give him a call at 714 960-2421 and tell him Mike Murphy told you to call. He can probably walk you thru it over the phone. Murf
Funnyguy
Old 02-14-2005, 03:45 PM
Murf- Thank You VERY much! Rick
Old 02-15-2005, 11:02 AM
I gave Dick Thorpe a call and he was very helpful. He also confirmed my suspicions that this is not a straightforward task (as if anything ever is). He indicated the handle comes off with a set screw, and then the panel comes off when the rear panel screw is removed.
The hook, however, is that the cable assembly is somehow fastened to the inside of the panel. He said that whatever holds it to the panel is often broken and you must fabricate something to re-attach the new cable. He said he sometimes frberglasses it to the panel? You must then adjust the cable and then re-install the panel assembly. I JUST CAN'T WAIT TO PULL IT APART AND GIVE THIS A TRY! I guess worst case is I drive to Huntington Beach and let Dick repair it, but I sure want to try it myself first.
Old 02-17-2005, 12:47 PM
If this continues to be a problem, just sell all the '89 Speedsters to me for ten grand apiece!
Seriously, I admire your choice of cars. They are destined to be a timeless classic.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 02-17-2005, 06:14 PM
Help! I don't have a speedster! You guys are so lucky.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 02-17-2005, 07:21 PM
Don't think for a minute we don't agree we're lucky! It's a really fun car, and you don't see many, except at large Porsche gatherings, even in sunny (not today!) So. Calif.. These cars weren't meant to be driven with the top up anyhow. I went to the Euro-car meet in Long Beach two Sundays ago. It started to rain, and the interior got a little damp, but I did drive home in scattered showers with the top down. Had a big damp grin on my face all the way home. No harm.
Old 02-18-2005, 09:57 AM
When I bought mine in 1999 I drove it home from Huntington Beach up 101 thru Reno where it started to pour and I was jamming dirty socks, underwear and anything I could find into the windows to stop the leaks....but it is a fun car!!!
Funnyguy
Old 02-18-2005, 11:33 AM
