-   -   I am such an idiot, Please help (http://forums.pelicanparts.com/porsche-911-technical-forum/207269-i-am-such-idiot-please-help.html)
mikes72t 02-19-2005 12:40 PM
Okay so I was going to start getting the car out of storage and I can't find the key anywhere. Yes it was my only one, I had meant to make a couple of copies.
Anyway.
Now what, does a locksmith make a key, or do I put new locks everywhere?
Humbly I thank you for any advice. You can laugh too if you must.
Mike
Oldporsche 02-19-2005 12:44 PM
I'm not laughing! I was working on my car in a body shop. Some vandals went through the cars in the shop. (1970E) They threw away all of the car keys that they could find, including mine. The shop was out of town. I had a key cut from the vin number. I would explore this route.
David Duffield
dtw 02-19-2005 12:44 PM
A locksmith can make a new key with ease. Open your wallet wide!
mikes72t 02-19-2005 12:46 PM
Will the Vin number work for a 72?
Any idea how much a locksmith would charge?
Mike
dtw 02-19-2005 12:49 PM
I'm thinking the VIN method won't fly for a '72. If it does, let me know! It would be helpful to me as well.
If you can manage to break into your car and then remove one of your locks, then you can take it to the locksmith and it'll be pretty cheap. Otherwise you're paying for a housecall at hourly rates.
Oldporsche 02-19-2005 01:01 PM
I remember the incident. The bodyshop was about 45 mi from my hometown. I called a locksmith, and he asked for my vin. He cut me the key (for a 1970 E) and gave me the code to make an original. I still use the key he made.
You might try this guy.
http://www.lockandkeyid.com/
He is a Porsche key specialist.
Good luck,
David Duffield
Grady Clay 02-19-2005 01:08 PM
Good old AAA.
K. lost her key to the Land Cruiser (in the flower bed as it turned out) and we couldn’t find the spare. The AAA locksmith showed up and made a new key and spare – no charge. The new key worked far better than the almost worn out original. A few days later I took the LC over to the locksmith (now with all the keys) and for $7 we have spares and everything works even better.
Best,
Grady
Zeke 02-19-2005 01:50 PM
$25 for a code cut here in LB.
jhc 02-19-2005 02:22 PM
I think I paid $150 when I lost the keys to my F250HD here in Northern Virginia. Since then the first thing I do if I only have one set is to make spares. Both 911's only came with one key.
yelcab1 02-19-2005 02:28 PM
I have spares made for the ignition key, the alarm activators, and the wheel locks. I am not paranoid, I have just paid those prices once before. The inconvenience is the worst.
dtw 02-19-2005 02:52 PM
Not for a house call!!
But it sounds like there are guys out there that can cut keys with an early chassis number - I'm totally impressed and stand corrected.
mikes72t 02-19-2005 03:14 PM
Originally posted by Grady Clay
Good old AAA.
Best,
Grady
Grady as usual I am in your debt, I hadn't thought about AAA, not I just have to push it into the street infront of the house and dial 222.
Mike
RC-Escape 02-19-2005 04:15 PM
I have only one set of the 3 keys you mentioned and would like to get a duplicate for each. Question, if I go to a local locksmith would he have the blanks for these three keys? Or would I have to order the blanks from porsche and take them to the locksmith?
Thanks.
RC-Escape 02-20-2005 02:57 PM
bump - thanks
rexav8r 02-20-2005 03:56 PM
What kind of storage?? Was the car even locked up where you had it?
I only ask because maybe you just tossed the key under a floor mat or in the ashtray, or glovebox....
Did you set the key down on a board or shelf or door sill on the side of the storage place???
Not being a wise guy, just giving some ideas of places to look...
(been there, lost that...)
good luck !
http://www.pelicanparts.com/support/smileys/sad2.gif
mikes72t 02-21-2005 06:08 AM
Yeah it is my garage unlocked, I have looked around all of the usual places and come up empty. I even got my wife to go and look around, she can find anything, but no luck. I know it should be somewhere obvious and easy and at some point I will stumble across it and kick myself for being dumb, I just know it.
Thanks for all of the advice.
Mike
