Lowering my SC
Want to lower the front suspension on my SC can anyone give me details on how to do it. The "101 project" book description is a little vague for me.
Thanks all.
Old 02-21-2005, 01:40 AM
The lowering bolt (one on each side) is 11 mm. Turn that bolt the same amount on both sides. Lefty Loosie lowers.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 02-21-2005, 05:03 AM
Chuck Moreland's Avatar
Get the weight off the wheels before before turning the adjusters.
In general, it is not wise to lower the front only. You need to maintain proper rake, front to rear.
It is best to corner weight the car after adjusting. But if you are making a very small adjustment, you can carefully turn each the same amount without a significant impact on balance.
Chuck Moreland - elephantracing.com - vonnen.com
Old 02-21-2005, 09:30 AM
coloradoporsche's Avatar
Be prepared to spend some time on this to do it right. I got my car into a very unstable balance by lowering incorrectly. Do some searches on the "tripod method". I found it to be very valuable in adjusting height without screwing up the balance of the car.
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 02-21-2005, 09:46 AM
1 turn is about a 1/4" ride height change. As Chuck said....less stress on the machinery if you do it unloaded...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-21-2005, 06:51 PM
Somatic Negative Optimist
Gunter's Avatar
Spray some oil on the 11mm bolts before you turn them evenly. How high is it now and how low do you want to go? 25 inches from the fender lip to the floor is good. And you do need to install the "bump-steer-kit", meaning spacers under the rack. Lowering changes alignment, especially camber, and is usually done on all four wheels to get good handling.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 02-21-2005, 08:04 PM
