Monkey Wrench
Spede's Avatar
Question Are heat exchangers from a 86-89 Turbo the same as 84-89 3.2?
Are the heat exchangers from a 1986-89 Turbo the same as the ones from a 1984-89 normally aspirated 3.2?
I gues what I'm asking is are they interchangeable.
Old 02-21-2005, 04:06 AM
Yes I believe they are the same.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 02-21-2005, 04:58 AM
Forced Induction Junkie
WERK I's Avatar
Steve,
I wouldn't think so since the exhaust plumbing for the turbocharger is routed differantly. The right heat exchanger(passenger side), has the exhaust exiting forward and uses a J-pipe to hook to a common flange off the left heat exchanger.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-21-2005, 06:42 AM
beepbeep's Avatar
Heat exchangers are different on 930 and 3.2 Carrera but passenger- and driver side exchangers are identical for respective car.
Main difference between exchangers is that 930 exchangers have thicker flanges towards heads with segments of pipe sticking into the exhaust ports. Also, Carrera has bigger Exhaust ports than 930. Other than that, routing of pipes is the same.
Part nr. for Carrera heat exchangers: 930 211 029 01
Part nr. for 930 heat exchangers: 930 211 033 01
Thank you for your time,
Old 02-21-2005, 07:17 AM
Monkey Wrench
Spede's Avatar
So then I could use 1987 heat exchangers on my 1984 non-turbo 3.2, right?
Old 02-21-2005, 10:14 AM
Monkey Wrench
Spede's Avatar
Can anyone confirm or deny this?
Old 02-21-2005, 04:32 PM
WERK I's Avatar
Goran,
What beepbeep tried to imply is the exchangers on 930's are interchangeable, left to right and the exchangers on 3.2's are interchangeable, left to right. They are not, however, compatable between one another. 930 exhaust ports are smaller than the 3.2's and the flange thickness is differant. 3.2's would have shorter exhaust studs than the 930's.
Bottom line, can't use 'em.
Dave
Old 02-21-2005, 04:43 PM
Monkey Wrench
Spede's Avatar
Got it! Thanks for the clarification.
Old 02-21-2005, 04:52 PM
