Flywheel removal
Are there some good tips out there to get the bolts out?
Old 02-22-2005, 12:33 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
My flywheel bolts took my neighbor and me (him with the wrench and me holding the engine steady) just to break them loose . After failing with a impact air gun we had luck with a large breaker bar.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 02-22-2005, 12:42 PM
VincentVega's Avatar
If they were put in with loc-tite, some heat will help.
Old 02-22-2005, 12:45 PM
Super Moderator
cstreit's Avatar
The bolts are very shallow and therefore easy to stip using a breaker bar. I've used heat and an impact gun successfully every time
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-22-2005, 01:01 PM
Friend of Warren
What Chris said, heat then impact gun.
Kurt V
Old 02-22-2005, 01:27 PM
jwmc1's Avatar
just took mine off, they were hard tyo get off at first, then I heated them up with a torch and they slid right off...
John
Old 02-22-2005, 03:50 PM
The last ones I removed came out supprisingly easy. I used a lock on the flywheel, supported the end of the breaker bar with a wood block and held them while a neighbor pulled down on the bar.
Marv Evans
'69 911E
Old 02-22-2005, 05:29 PM
