rfuerst911sc's Avatar
results of headlight relays and new bulbs
I ordered a Marcus Sucro relay kit about a year ago and got around to installing it yesterday. It only took about 30 minutes to install and that includes soldering 2 wires. After the relay install I put some Narva 90/100 watt bulbs into my US spec H4's and had a chance to drive at 5:30 this morning and all I can say is WOW!!! I can see much better and the headlights do not seem to dim at idle,this is a easy,cheap and effective upgrade.
Old 04-10-2005, 01:29 PM
you can max out the adjustment by raising the beam a little at a time till they flash you, then lower them.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-10-2005, 03:57 PM
Is the relay so you can run 90/100's? I thought I caould just change bulbs to an 80/100 from the stock bulb.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 04-10-2005, 04:26 PM
relays remove bulb current from the switches. The other thing to keep an eye on is the bulb socket with bigger watt bulbs. Some have reported toasted sockets or fires starting. High temp/watt sockets are available or just remove them and attach wires directly to the bulb till you get them if you see a prob coming.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-10-2005, 04:33 PM
Good point about the switch. Thanks
Old 04-10-2005, 07:36 PM
