Suspension rebuild 101
I am about to start a suspension rebuild on my 73T coupe. I have been collecting parts and I think I have just about all I need. I will be installing front and rear torsion bars (21&26), front and rear Elephant bronze bushings, front and rear Bilsteins (HD fronts, Sport rears), and sway-a-way adjustable rear spring plates. I have the foam seals for the front bars and the rubber seals for the rear covers. What I would like to know is: 1) are there any other parts I will need? and 2) is there anything else that I should do "while I'm in there"?
The car is used for back road tooling around and rides on 16x6 and 16x7's. Any suggestions would be greatly appreciated. Thanks.
Joe
Old 02-24-2005, 04:52 PM
pwd72s's Avatar
I'd suggest a good corner balancing & alignment when you're done. Also, you might consider turbo tie rods if you don't have them already...
Old 02-24-2005, 04:55 PM
djmcmath's Avatar
Consider some kind of treatment for the road-exposed bits -- powdercoating, zinc-plating, and POR-15 seem to be popular options. Rust is considered a good option for lightweight, and it seems to be getting more popular with time. If you're checking tie-rods, you should also take a look at wheel bearings, brake rotors and calipers, and ball joints. If you don't know when your rubber brake lines were last replaced, it could be time. Check the calipers for leaking. Oh, and the parking brake is an easy thing to get at, if you have everything torn down, anyway.
That's all I can think of, for now.
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 02-24-2005, 05:04 PM
randywebb's Avatar
the top mounts for the struts - that rubber gets old too....
look in the Perf. Prod. catalog and get their diagram that shows all the rubber bushings F&R and make sure you have new everything.
what about replacing the rubber for the sway bars?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-24-2005, 05:13 PM
Senior Member
Superman's Avatar
I'm no suspension expert, but 21/26 with Sport shocks on the 21's and HD's on the 26's is unusual. I wonder if someone could comment on the handling of this combination. Usually, Sports are installed on the rear, and 21/28 torsion bars. so, comparatively speaking, your front will be stiff and your rear will be softer. There might be some understeer.
Mocha 1978 911SC. "Coco"
Old 02-24-2005, 05:21 PM
Thanks. I did plan on bead blasting the front a-arms and Wurth rustguarding them. I also planned for the corner balance and alignment. I never gave a thought to the sway bar bushings or the shock top mounts. My list grows. Anything else?
Old 02-24-2005, 05:22 PM
Sorry. My mistake. The HD's Will be on the front and Sports on the rear. Good catch.
Old 02-24-2005, 05:25 PM
Zeke's Avatar
Did you also get Elephants self aligning mounts? If you did, you will need longer 12mm bolts in the front. For me, there weren't enough threads catching in the mounting points.
I broke off a spring plate bushing holder bolt. I would get new bolts everywhere now.
Old 02-24-2005, 07:00 PM
disband
juanbenae's Avatar
ball joints for the front? while yer in there,,, ya know.
Old 02-24-2005, 07:17 PM
Milt,
I have been on the fence about the self aligning mounts. What are your impressions? Do you remember the pitch and length of the bolts? Thanks.
Joe
Old 02-25-2005, 03:29 AM
those washer stacks are close to 6mm I used 1.5 X 45 bolts
mine are 10mm though, maybe different on an older car?
If you even have a hint of binding I'd get the mounts and washer sets. It sucks doing the front end twice
Old 02-25-2005, 04:37 AM
