-   -   RSR shocks, special hardware to mount? (http://forums.pelicanparts.com/porsche-911-technical-forum/208024-rsr-shocks-special-hardware-mount.html)
Porschekid962 02-23-2005 11:00 PM
IF I want to put the RSR coilovers on my car, 1972 911T, do I need any special hardware for the upper mounts? I was planning on using the Elephant Racing monoball in the Elephant Racing camber plate mount. Is that all I need to bolt the coilovers in?
Porschekid962 02-24-2005 02:02 AM
anyone?
alfizzo 02-24-2005 04:28 AM
call the racer group.
Wil Ferch 02-24-2005 07:25 AM
Do call Chuck Mooreland or others...but my opinion is this:
Be careful in that the loads are now through a different path....the coils will now load up the shock towers..something they were never meant to do originally. RSR coil-overs are best used when the shock towers are re-inforced or tied into a roll cage structure......
IMHO......
Wil
Jeff Alton 02-24-2005 07:27 AM
Thw shocks come with there own mounting hardware, however you should reinforce the chassis in that area.
Jeff
Chuck Moreland 02-24-2005 10:59 AM
You need hats and the coils. You can also put in a bearing kit to prevent wind-up when steering, though the monoballs will largely mitigate the need for this.
Porschekid962 02-24-2005 11:16 AM
Ah just the man I was hoping to hear from. I assume you sell the springs and hats even though they are not on your website. A call to Elephant is going to happen sooner than later. Now if I only had more money....
Thank you Chuck.
