| rfuerst911sc |
02-27-2005 03:52 AM |
AC upgrade-update-still need help
Well after last weeks setback of a leaking underbelly condensor I removed the condensor and found a local radiator shop that brazed it.I installed the condensor yesterday,pulled a vacuum and had another leak.I eventually traced the leak to the flare fitting on the suction side of the expansion valve,installed a copper sealing washer and pulled a vacuum again and voila no leaks!!!! I pulled a vacuum for 1 hour,turned off the pump and the needle held rock steady for a 1/2 hour,great I thought.Now I grabbed one of the cans of HC12A along with the can tap and hose assy that came with it,hooked it up to my charging manifold,opened everything up and no gas going into the compressor!!! Now what? I fooled around with that can tap setup for an hour and can't get any gas to come out of it,can I have a defective setup? The handle feels real heavy as you operate it to pierce the can,almost like the o-ring or gasket is bunched up.I even removed the screw on hose that goes to the valve,inverted the can and opened the valve and nothing,but if I unscrew the unit from the can as if I was going to change cans the gas starts coming out,any ideas guys??Anyone in Central Florida have a R12 can tap I can use?
