Paint Experts
I am thinking of buying a fiberglass hardtop from widebody911 but I don't want to paint the entire car- my painter says he can match the paint so close you can't tell the difference between the existing paint and the new paint on the top... I find this hard to believe what do you guys think? Here is my car- L661 Metallic Blue
ELVIS 84 CAB -SOLD |
When my wee wifey ripped off the front of our Audi by driving backwards from the concrete wheel stop, we took our car to the local Porsche painter, and he matched the Mica Volcano Black perfectly - even to the tiny green metal flakes that show up only in bright sunlight.
We were flabergasted!!! It is amazing what modern paints (and painters) can do nowadays!!!
Andras 1983 911SC The Chocolate Kiss 1998 Audi A6 Quattro (Family Car) 2002 Audi TT Roadster (Wifey's Car) 1992 Mazda Miata (Daughter's Car) 1991 Honda VFR750F Interceptor 1982 Honda VF750S Sabre |
Modern paints don't have that much of a tendency to fade, so often a very good match can be had from merely the provision of the original paint code to the supplier.
Mixing, even without a number, is also no longer a hit or miss afair, and you'll probably find the new paint to be spot-on. Willem
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
Friends of Warren
where do you get the original paint codes?
For example I have a 1988 Guards Red.... we are about to do a widebody conversion... How do I get the "right" paint? |
Recreational User
Matteo, in your trunk there should be a paint code sticker affixed to the inside of the right fender, which you can see if you lift up the carpet.
Friends of Warren
Dave
Thank you very much. I will look it up! |
Thanks Guys - Any other opinions? I want to be sure before I end up with a 2 tone car...
MBruns for President
Beautiful color 84cab = beautiful car...
Looks like the name is Slate Blue Metallic Clearcoat L661/X6 Go here and look up your year and model http://www.paintscratch.com Can upload a picture for some reason
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Is widebody making these tops now? Cost?
Tru6 Restoration & Design |
ELVIS 84 CAB -SOLD Last edited by 84CAB; 02-27-2005 at 10:28 AM.. |
When I had my headlight bezel painted, the body shop used a method (laser, I believe) from the fuel filler door. It matched perfectly to the rest of the car.
The Fox Carrera |
Air Medal or two
Belive it!!!!!!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
