after clutch job, engine starts, backfires, stalls
Basically, that's it. It starts for 1-2 seconds, backfires via the pop-off valve and stalls.
The egr is not well connected, but it was like that before i had the engine out.
I did not touch the distributor or spark plugs/wires.
Any ideas?
Nikita
1977 911s Targa
Old 02-27-2005, 10:35 PM
buster73's Avatar
Checked the ground wire between body and engine/gearbox ? Might also be dirt in the fuel lines that came loose when you worked on the fuel lines.
Regards,
Guenter
73.5 911T, mod
Old 02-27-2005, 10:45 PM
I am not sure about the groud wire. Where would it be?
I think I connected all the wires correctly and the fuel lines were clean.
Nikita
1977 911s Targa
Old 02-27-2005, 11:02 PM
buster73's Avatar
Should be at the forward end of the gearbox near the gearbox mounts.
Regards,
Guenter
73.5 911T, mod
Old 02-27-2005, 11:05 PM
Hmmm,
I never had the tranny (915) out. The backup light switch could be plugged in backwards, but other than that I did not disconnect anything back there.
Nikita
1977 911s Targa
Old 02-27-2005, 11:07 PM
brake booster hose attached?
206 637 4071
Old 02-27-2005, 11:10 PM
