78 STROSEK's Avatar
Lsd Tranny
CAN ANYONE TELL ME HOW TO IDENTIFY A LSD TRANNY IN THE CAR
Old 02-28-2005, 03:11 PM
Jack up so both rear tires are off ground; put in neutral and then spin a wheel. If both spin same direction, you have LSD. If not, you don't. Just learned this in my thread. If you know option codes on your car, it is M220.
Old 02-28-2005, 03:41 PM
78 STROSEK's Avatar
THANKS I'LL GIVE THAT A TRY.
Old 03-01-2005, 05:49 AM
If you look underneath the car...at the bottom of the tranny on the flange projection near the drain plug....if there is a "12" between the type and serial numbers....its an LSD. Best check is wheels in the air to see if they rotate the same direction.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-01-2005, 12:10 PM
