Weaver's Avatar
What is "room temperture" ?
My '88 Carrera ( 88k miles ) has developed a "bucking" problem under acceleration. I checked the resistance of the head temp sensor and it came up with .65 ohms. In reading one of the Pelican tech articles it says that it should be between 1 and 2 ohms. My Bentley book states it should be 2.2 to 2.8 ohms at "room temperature". Its 35 degrees F here in Indy. I always assumed room temp was around 70 degrees. How am I suppose to check this sensor if its too cold out? Am I going about this the wrong way?
Thank for your time
Weaver
Weaver
'88 911 Targa
'03 911 Turbo, X73 Susp.
'13 Panamera GTS
PCA member Central Indiana
Old 02-27-2005, 05:13 PM
Early_S_Man's Avatar
Porsche Crest
Maybe this isn't the best month to be checking that sensor ...
Hair dryer or heatshrink gun??? Heated garage???
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-27-2005, 05:19 PM
Wider is Better
wholberg's Avatar
In several industries, room temperature is regarded as 23 - 25 degrees Celsius, which is 73.4 - 77.0 degrees Farenheit.
Wider is Better
Old 02-27-2005, 06:45 PM
pwd72s's Avatar
Which all of us will reach, probably, sooner or later, sometime. (According to Jocelyn Elders, former surgeon general.)
Old 02-27-2005, 06:57 PM
ausdilecce's Avatar
Weaver,
just take the sensor out and bring it into the house.. wait a bit for it to warm up, then test it...
Bucking .. things to check
sensors
afm ( http://frwilk.com/944dme/afm.htm )
vacuum leaks
My bucking prob turned out to be the wire loom running along the firewall. The thing was it would buck in 1st and 2nd only and NOT AT ALL in reverse. It turned out that the wireloom was pulled tight as I accelerated forward and so would buck forward, but it would not buck when accelerating backward cuz the wire loom would get slack as the engine rotated slightly forward..
I mention it because if all other 'normal' reasons don't pan out, start checking for 'weird' reasons.
Good luck
1987 ROW Carrera Targa, SW chipped
1983 U.S.A. SC coupe ( bro has her now )
Old 02-27-2005, 11:09 PM
