SC bucking...
78 sc bucks while decelaration. also while warming up idle starts to surge up and down hunting.
Could I need a new warm up reg. or is my mixture out of whack?
Old 02-28-2005, 03:20 AM
jwmc1's Avatar
could be a vaccuum problem...I am not sure, but I think in 1978 you could still check for some vacuum problemsby removing the oil cap. Ifc the RPM's fall a lot when you remove the cap then you are likely fine, but if there isn't much of a change you may have a leak somewhere. The WUR is expensive, I would rule out other things first. Try a search, I know there have been other discussions about this topic.
John
Old 02-28-2005, 03:42 AM
jwmc1's Avatar
although, I am not sure I would do it, you can try a small spray of starting fluid around the intake...takle a good look at the rubbet boot on the CIS, sometimes they crack and suck too much air...unfortunately with these cars it could be a lot of things, but you should try to rule out the cheap $tuff fir$t.
John
Old 02-28-2005, 03:49 AM
Designer King
Paulporsche's Avatar
Your WUR may be slightly out of spec, but it could also be simply that your mixture is just slightly too rich. Try leaning it in small increments (about 1/16 turn @ a time) and see if it improves. Don't go more than 1/4 in all and if it doesn't help, put the setting back to where it was and look elsewhere.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 02-28-2005, 10:13 AM
thanks i'll try to lean out the mixture
Old 02-28-2005, 01:54 PM
