Does this wire need plugged in?
Was admiring my work on the recent installation of my fuel accumulator (checking for leaks) and noticed a wire thingy that was not connected. Looks like it plugs into the other wire thingy just above and behind it in the photo. What is it for and should I plug it in? Runs fine. Excuse the ignorance but I am just getting started in DIY.
If I plug it in would that qualify as my third project? Thanks to all Steve Bagpipers and Porsche's are a small group indeed!
Sorry 81 SC non turbo.
Steve |
Looks like the power wire for your electric heater blower...
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Exactely . Look further back in the photo for the female half of it.
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Thats why it might be disconnected. I was told the motor needed replaced, Heat works ok after about a mile or 2. Even in 5 below!!
Thanks |
X/A |
Buy them, sell them
Mine is also unplugged.
Should this blower work after the ignition is switched off? I plugged mine in and the blower worked on and off after I parked the car. I didn't know if it's supposed to run like that or not, so I unplugged it again.
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
On my 82SC the blower works only with the ignition on and at least one of the heat control levers between the front seats on. It doesn't cycle on and off.
-Mac |
Screw it, don't plug it in backdate the heat and loose that 2 lbs.
Disregard Masraum's comment.
![]() If you're in CO, you'll definitely want heat and defrost and this little motor is the turbocharger for your heat. Plug it in and you'll see a definite heat\defrost improvement immediately! ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Warren Hall Student
Diffinently one of those "If it had been a snake it would have bit me." moment.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
I think I might agree with masraum, the heat could be backdated.
The blower motor helps push heat only during low rpm times like idling. If you backdate you aren't eliminating the heat , you'll actually have more heat then you are use to because a non functional heater blower is an obstruction in the heat path. Once you remove it the engine fan pushes heat more directly into the cabin, especially as the revs increase. It also cleans up the engine compartment and makes the car lighter changing your power to weight ratio!!! You'll be hotter and faster! |
