fog lamp grill
I have decided to remove the solid fog light covers on my early 911 to allow a little more air to flow to the front brakes. Has anyone fabbed a grill, screen or perferated cover to give the empty hole a little more finished look? pics would be great
Thanks,
Matt
1966 euro 911
Old 03-02-2005, 06:19 PM
pwd72s's Avatar
Imagine replicating your horn grilles...slanted in the direction of the brakes. Should be an easy job, if they are unframed...
Old 03-02-2005, 06:34 PM
I was thinking the same thing, but not sure how easy it would be? Anybody have a donor grill.
Matt
Matt Cooley
1974 911
Old 03-02-2005, 06:39 PM
O.K. this is the grill I have been working on. Stainless steel screen over stainless rod shaped to fit opening, right now mounted with black upholstery thread. (non permenent) A modified horn grill may be more consistent with the other trim parts, any feed back would be appreciated.
Matt
Old 03-02-2005, 07:30 PM
Banned but not out, yet..
RSBob's Avatar
First, I would cover the bracket behind the grill with somce type of black tape so it doesn't show through whatever you use. I like the slat idea similar to the horn grills. Ones can be found for cheap at MidAmerica - at least cheap enough to modify... Post the pics when done.
Old 03-02-2005, 08:38 PM
Yeah, I was going to paint the mounting plate behind the grill black to try to make it dissapear, in fact that was the main reason I was looking for some type of grill to cover the hole. With the fog lamp covers removed it just looks like the car is missing trim parts.
Matt
Matt Cooley
1974 911
Old 03-02-2005, 09:17 PM
