Raynald's Avatar
Cams timing questions !
Hello !
I am not sure about my process !
I try to do the timing like the Wayne book explaine but I think I mist some thing about it ( my understanding of english ), My cams is Solex cams and my engine is 2.7 L with RS pistons.
my setting cams is 4.3 mm.
whe I turn the cam with the tool the pîn off the valve touch the piston before I can read 4.3 mm on the dial,
where is my problem ?
Ray
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 03-01-2005, 08:04 AM
Raynald's Avatar
Hello
I recheck tonight and I have 4.3mm at Z1 after a 720 turn and install my rocker of exhaust adjust the valve and when I rotate slowly the crankshaft for testing the exhaust valve touch the piston...
what is wrong ?
Ray
Old 03-01-2005, 06:31 PM
You started at cylinder #1 at Z1 firing position, and then turned 360deg to Z1 cylinder #1 overlap to set #1 cam timing correct ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-01-2005, 11:36 PM
Raynald's Avatar
Yes, RoninLB
This is my process !
The cam is in good side and piston in good position...
High-lift, high-duration Camshaft Timing left side
1. Line up crank @ Z1.
2. Clamp tensioner idler arm.
3. Dot on left and right hand cam in up position.
4. Install rocker arm #1.
5. Adjust valve .10mm (.004 in)
6. Attach dial indicator to #1 (depressed at least .4 in)
7. Install small dowel pin into obvious hole.
8. Tighten camshaft nut to final torque 110 lb/in.
9. Rotate crank 360° lining up Z1 mark. (note how far dial gauge moves). Camshaft should have rotated 180°.
10. Hold cam securely w/camshaft tool and remove nut with crows foot.
11. Remove dowel pin.
12. Rotate cam until valve overlap is reached. (Solex cams ) .17 inch nominal or 4.3mm.
13. Replace pin.
14. Rock the camshaft back and forth to check backlash.
15. Hold camshaft and tighten nut.
16. Rotate crank 720° Z1 should be lined up. Indicator should be in range.
all is done and i begin to adjust exhaust valve #1 and I rotated for the next and check for 720° and the valve touch the piston...
I don't know what I do wrong but some thing i mist...
it is new cams with new pistons (RS)...
Ray
Old 03-02-2005, 05:54 AM
walt's Avatar
Technique sounds correct to me. You may want to post this on the Engine Rebuild Forum.
Walt
82SC 3.0
81SC 3.6
Old 03-02-2005, 03:42 PM
Raynald's Avatar
Hello Walt !
Is this possible for a not good overlap mesure ?
Raynald
Old 03-02-2005, 05:51 PM
walt's Avatar
Do you have only the number 1 intake rocker installed?
Walt
82SC 3.0
81SC 3.6
Old 03-02-2005, 08:16 PM
camgrinder's Avatar
Hi Raynald,
Are you sure you have the left cam in the left position and the right on the right side? Waynes book has a diagram showing which cam is left and which one is right.
The RS pistons should clear the Solex cams without a problem,
are you positive they are RS pistons?
John Dougherty
Dougherty Racing Cams
Old 03-02-2005, 08:51 PM
I can't think of hard answer. Is it a possibility that the pistons are installed wrong ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-02-2005, 09:16 PM
Raynald's Avatar
Hello Guys
Yes the pistons is in the good position and the cams is in the good side
I double check ! I have the wayne book and the Bruce Anderson book for reference,
Raynald
Old 03-03-2005, 05:22 AM
Raynald's Avatar
Pistons
Hello Again !
This is my pistons position .
Ray
Old 03-03-2005, 05:28 AM
Re: Pistons
Hello Ray
looks good to me.
Here's mine.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-03-2005, 05:53 AM
Raynald's Avatar
Hello Guys
I am right now....
This is important to have a dial! but it is better to know how it work ...
I don't take the good scale on it !
0.17 inch.: is one total turn plus .7 more...
I am OK at Z1 and all my valve adjusment is done whitout touch !
Thanks for your Help All.
Raynald
Old 03-03-2005, 08:36 AM
