LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
Britain Smith's Avatar
37 Degree Flaring Tool for Stainless Fuel Lines
I am in the middle of routing new stainless steel fuel lines through the tunnel of my car and I now need to go into AN6 braided lines to make the trip up to the engine bay. I have all the AN fittings along with some tube nuts and tube sleeves, but I can not seem to locate a 37 degree flaring tool to make the proper flare on the steel lines. Do anyone have any experience with this exercise? Does anyone happen to have a flaring tool that can make 37 degree flares that I can borrow?
Thanks,
Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 03-31-2005, 05:06 PM
abit off center
cgarr's Avatar
Here is the one I have, http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=212FB&ReturnPage=/shop/search_result.aspx?PageNo=3 I have used it with stainless steel tubing but you have to be real carefull and use a lot of lube but it worked OK for me. I could send it to you to try but they really are not that much money to buy. Check for a local EAA Chapter in your area, someone there should have one you could use.
Craig
______________________
Craig
G2Performance
Old 03-31-2005, 05:34 PM
