js1099's Avatar
Radar Detector Riding Fog Light?
I noticed my passenger side fog light was aimed way low. There is a box strapped to the top of it, is this an after market item, like a radar detector? Removing it would help readjust the fog light, I plan on just cutting the wire to the unit. Also, has anyone had any luck readjusting the fog light with the horns in the way, or should I just remove the whole assembly and loosen the bolt off of the car? The bolt is very difficult to get leverage on with the horns in the way. Had a pic, but it wouldn't upload?!?!
'88 Triple Black Cab - 42K Miles
'01 Acura 3.2 TL
'03 Honda Pilot - EX-L
Old 03-04-2005, 06:17 PM
Could be a laser diffuser. I actually have one that I've attached in the same spot. Don't cut wires - just trace them to the source and unplug, or cut them there. You can always resplice.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 03-04-2005, 06:41 PM
js1099's Avatar
Got the pic uploaded finally, any thoughts?
'01 Acura 3.2 TL
Old 03-05-2005, 06:27 AM
Me like track days
Craig 930 RS's Avatar
Looks like the F&R radar unit by Escort
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 03-05-2005, 07:30 AM
js1099's Avatar
Well, I followed your advice and it turned out to be a K40 Sonaradar SS1000, roughly 17 years old. It probably cost $1000 back then too. Anyway, the line was cut about 2 feet in, and I just pulled the thing out. Got the fog light adjusted upward too, by getting a socket in through the opening above the fog light and maneuvering below. Now, I don't look lopsided anymore. Thanks for the tip.
'01 Acura 3.2 TL
Old 03-05-2005, 09:04 AM
