Clutch T/O Bearing Question
I'm about to join my newly synchro'd 901 to the engine. Should the T/O bearing surface where it contacts the pressure plate fingers be greased? I know the input shaft splines need to be.
Another question, is the T/O bearing in constant contact with the pressure plate when the clutch is disengaged? |
Air Medal or two
you can put a dab of something on it...I do,but I doubt anything stays there very long...as for contact?? depends on the free play adj.Everone has thir own place,,I run mine a little loose.I think if you go by the book you will be pretty much tuching it.
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
