Powder coating
I am considering having the muffler from my 73 911T powder coated.
Has anyone done this, and if so, have you been successful? Does the muffler get too hot for the powder coat? Will the heat exchangers handle the heat? Thanks |
The muffler will get too hot for normal powder coating. You can try ceramic coatings which can withstand the heat.
Regards, Guenter 73.5 911T, mod |
There are High-Temp powder coatings. However, exchangers may be pushing the limit. a search should bring some joy on this subject.
Warren & Ron, may you rest in Peace. |
I would rather be driving
Jet hot or other ceramic coatings are much better suited to these applications. I personally would not powerder coat my exhaust system. Too much heat.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I ceramic coated my muffler and heat exchangers and they turned out great. I was quite happy with the results given their initial condition. If you need some more info pm me.
1971 Targa RS - Sold 1964 BMW 1800Ti 1969 BMW 2002 |
Jet Hot
Hi Jagular,
When I did the rebuild, I had the powdercoater coat the muffler also, and it burned off almost immediately after firing up the car. Sort of interesting actually, the burn-off leaves a white powdery residue, but the two ends are still beautifully black. The first place the powder burned off is at the point where the exhaust hits the back "face" of the muffler, right at the flanges. All the other sheet metal is still satin black, very pretty, and dust and "grime" roll right off with diluted Simple Green. But the muffler definitely gets too hot. Once I pull the muffler again for whatever reason, I'll use VHT, which has worked in the past without burn-off.
Andras 1983 911SC The Chocolate Kiss 1998 Audi A6 Quattro (Family Car) 2002 Audi TT Roadster (Wifey's Car) 1992 Mazda Miata (Daughter's Car) 1991 Honda VFR750F Interceptor 1982 Honda VF750S Sabre |
