mph to rpm
As my tach is broken and I do not want to overrev, is there any relation between mph and rpm’s for each gear that I can use as reference?
My car is a 2.0 Lt with a 601 trans.
Old 03-05-2005, 04:24 PM
....ok....
...let me ask it better,
Can any of you helpl me with the approx. mph for each gear (1,2,3,4 & 5 th) for 4000 , 5000 and 6000 rpm's, so as not overrev my 69 S - 601
thanks
Old 03-06-2005, 06:34 AM
Early_S_Man's Avatar
Porsche Crest
Your transaxle is a '901' ...
You need to determine the transaxle 'Type' number ... it is stamped on the bottom near the drain plug, and is of the form 901/xx ... and is in close proximity to the serial number of the transaxle.
Your tire brand, model, and size for the rear wheels is also need to determine speed accurately from rpm.
Here are some useful charts with the possible choices of transaxle:
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-06-2005, 06:55 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Originally posted by targa6911s
....ok....
thanks
If you would be so kind to provide the ratio for each gear, the final drive you are using and the tire size, I would be happy to make a gear chart for you.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 03-06-2005, 06:56 AM
