fireant911's Avatar
Sway Bar Manufacturer Identification
The bar is on my 1981 911SC and I have had an intermittent 'clunking' from the driver's rear wheel wheel most noticably when making left turns. Today I was examining potential causes of the troublesome noise when I noticed that the bolt on the driver's side was in contact with the trailing arm whereas the passenger side had ample room away from the trailing arm. I was able to reposition (the bracket attached the the sway bar was almost at the end of the sway bar and the threaded piece that is currently pointed upward was at a severe angle). I drove the car after hopefully correcting this problem and absolutely no 'clunking' was heard - but I may want to contact the manufacturer to ensure the the procedures I used were correct.
With the vast knowledge of folks out here, could someone please identify the manufacturer of the sway bar from the picture below:
Daryl G.
1981 911 SC - sold 06/29/12
Old 03-05-2005, 03:29 PM
KobaltBlau's Avatar
manufacturer is weltmeister. If you change the position of the clamp on the bar you will change your handling characteristics, so be careful.
Andy
Old 03-05-2005, 03:54 PM
