Need some quick and serious help
Just put Brother's engine back in the car. Started up on the first try but doesn't run for long. Bogs down and is real rough. Plug wires should still be going on the same way. Pumping the throttle barely changes the rpm and then will cause a backfire and stop the motor.
Any ideas? Exhaust is cool. We adjusted the valves, but didn't make a big enough change to warrant this. (I think) Please help!!! |
You need to provide more complete info
Distributor been out? Possible solution, try rotating distributor 180 degrees.
What year?
If CIS, check WUR and AAR, and control pressures. |
There is some valve noise coming from #1. I think I boofed the first Valve adjustment. I might have rushed it. I barely adjusted them though and they seemed tight before so I didn't think it would have this effect. I can coax the idle up to 1000 by holding the throttle but then it starts to backfire. The distributor is back on and the wires match up correctly. I didn't change any timing (that I know of). It idles at 740 RPM now.
80. I don't have the tools for that. |
Rikao4.Just because the plug wires are installed correctly, doesn't mean the distributor is is installed right. The rockers need to be on the base circle of the cam, with piston atdc on #1 cylinder.Dan
I just reinstalled the engine in my wife's 1977 911S. Same symptoms. Poor starting, rough running, although after sitting 24 hours, last night it started and ran better but still not right.
I did not do any internal work to the engine while out except adjust the valves. I took it out primarily to install a new clutch and exhaust systems. What is the WUR and AAR referred to in Rikao4's post ? I think I need to be troubleshooting the fuel sysem, but I'm open to any suggestions. Prior to this, the car would sometimes run a little rough like this but clear up within 30 seconds or so and run smoothly. Could happen hot or cold. Thanks ! |
Chris,
Do a search for the Warmup Regulator (WUR) and the Auxiliary Air Regulator and Valve (AAR and AAV). They control the mixture while the engine is running (WUR) and keep the revs up during warmup (AAR). Usually rough running, especially while warming up, is caused by a malfunctioning one of these. Rickao4 and Chris, You will need a fuel pressure gauge (about $60 from Whitney) to check the control pressures, which will tell you if the WUR is OK or not. |
Thanks for your reply, Paul
Also, out of curiosity in case the CIS system checks out oK, is it possible that an error in valve adjustment could be causing this ? I just pulled each spark plug connector with the engine running and it sure seems that cylinders # 2, #4, and #3 are not firing (no RPM drop) while disconnecting the others exhibits a noticeable drop. They happen to be sequential in the firing sequence. Does this point to a possible valve adjustment issue ? Although I am pretty confident the valve adjustment was done properly, I have to ask ... Can an error in valve adjustment result in piston-valve contact ?? Or am I just looking at re-adjusting ? |
Hi Chris,
You might also check to see if you installed the ignition wires "backwards". Note that some distributors rotate clockwise, others counter-clockwise. I thought I knew which way mine rotated, but when I first re-installed my rebuild, I had gotten them "backwards. The car ran very roughly, and when I put the wires on correctly, it now runs quite nicely. |
When I re-installed my engine, it started on the first go but ran very poorly -- extra-super-rich. Turns out I had almost, but not quite, plugged in one of the wires. Check through your engine bay to make sure you actually plugged everything in -- it only takes one loose connection to make the whole thing not work.
Dan |
Just a question: What would be the effect of having too little clearance on the valves?
When disconnecting and reconnecting the fuel lines it is possible that dirt comes loose and blocks fuel lines or filter. Some fuel still reaches the engine but not enough to keep it running properly.
What else was done to the engine while it was out of the car?
I would check all the connections from the engine removal i.e. all the wires, hoses and grounds. I also have to agree with the earlier post that the distributor may be off, happened to me and you can chase down every wire before you realize that was the problem. Also check the rotation of the distributor and make sure your ignition wires are in the correct firing order. |
Why not check your valve adjustment? Then you can move on to other things.
And if you can get your hands on the fuel gauge that would tell you about the WUR. Do you have a popoff valve in your airbox? Have you checked for air leaks? Are your ignition wires, cap and rotor good? Have you checked the mixture? How old is the fuel filter? |
To PaulPorsche et al
I took the advice and re-checked the valve adjustment. Sure enough, the exhaust valves on the three non-firing cylinders were mis-adjusted so those valves were not seating. I readjusted them, checked all the others, and the engine runs smooth as silk. Guess I wasn't as careful as I should have been while adjusting the valves the first time ... but will be next time ! Thanks for all the feedback. Hope Rika04's situation is as easy a fix. |
Thank you all for the input / note from the shop
1. we broke a grounding wire in the back harness which disabled the "frequency valve"= fuel regulator fritz 2. valve job was blessed and deemed worthy 3. the # 2 intake runner not seated completely=leak we did it backwards / should have tighten the runner 's first, then the clamps for the boots (me) Brother scored a "duck" from this misfortune / got tagged by a F350 last week. I'm still going to do mine, have no fear the Pelicans are near. Rika |
| All times are GMT -8. The time now is 11:22 AM. |
