-   -   How do you know if you're flaming? (http://forums.pelicanparts.com/porsche-911-technical-forum/209752-how-do-you-know-if-youre-flaming.html)
porschett 03-06-2005 10:48 PM
"Not that there's anything wrong with it" - Seinfeld :D
Seriously...Other than having someone drive behind you, how do you know when you're shooting flames? Does it happen on decel only? Between shifts only? It it followed by a popping sound? Can plugging the decel valve cause popping/flames?
I did spend an hour searching...I came accross one reply that unplugging the decel does cause flames, but wanted others opinion.
Reason why I ask is I have a high idle after warm up and trying to determine if it's the decel valve or AAR.
Thanks.
