alternator numbers
I've got a '71 911E, basically stock & am having an ongoing problem keeping batteries charged & alive, might have something to do with not being driven enough. But can anyone tell me what my alternator/voltage regulator should be discarging at?
HELP, this must be easy for you guys!!
If I understand your question -- your '71 should have a 55 amp alternator.
Jerrry M '78 SC |
Perhaps I misunderstood your question, so here's another answer.
With the engine running at approx. 2000 RPM, put a VOM on the battery terminals, you should, at least, 13.5 volts (charging) on the VOM. Jerry M '78 SC |
| All times are GMT -8. The time now is 05:03 PM. |
