-   -   Whale tail louvers blackout, is there a specific pattern??? (http://forums.pelicanparts.com/porsche-911-technical-forum/210071-whale-tail-louvers-blackout-there-specific-pattern.html)
BeauBlues 03-08-2005 09:51 PM
Ok, a little confusion on what I should do. I am in the slow process of prepping my turbo tail for paint. I have seen some differences in the size and shape of the black inlay on the louvers section. Is there an exact size and shape of this section that should be painted. Or does anyone have a template that i can use to paint it with. Well anyway here's a picture of what im talking about.http://forums.pelicanparts.com/uploa...1110347486.jpg
BeauBlues 03-09-2005 08:32 AM
bump,....anyone?
rick conrath 03-09-2005 08:43 AM
It may be located in the body section of the factory manuals. Let me look at mine, if I can readily find the CD. More than likely, there is a digram that indicates the size and shape of the paint border.
Rick
'78 930
kach22i 03-09-2005 08:47 AM
Does anyone know why the louvers face the other way in the later 993?
http://forums.pelicanparts.com/uploa...1110386820.jpg
BeauBlues 03-09-2005 11:55 AM
Hey Rick, if you find out the info, I'd be glad to know. Any painters experienced with this, I would like to hear you input on this too.
BeauBlues 03-10-2005 12:00 PM
Bump, All I need is the measurements of the black portion in the tail.
RickM 03-10-2005 12:11 PM
Some years were all body color. Also, many wings were prepped after the fact by dealers so that adds to the variation.
kilodawg 03-10-2005 12:14 PM
Can't help much but I repainted the black portion of my wing a while back using the original line as a guide. I'm pretty sure there is a constant border size around the louvers so that when you find out exactly what it is you would just need to measure it around the wing. Probably real close to 3/4 inch in my mind eye anyway. I can check when I get home if you like.
rick conrath 03-10-2005 12:53 PM
I will pull out my factory manual tonight, and post anything I find tomorrow.
Rick
'78 930
randywebb 03-10-2005 01:11 PM
Dr. Ed E. Size knows why the louvers face the other way...
rick conrath 03-11-2005 07:00 AM
Well I looked through my 930 workshop manual and didn't see anything. I could measure the border around mine this weekend and get back to you.
Rick
'78 930
'89cab 03-11-2005 07:54 AM
I painted a factory turbo tail a few years ago. Mine had a very fine indentation/line/guide around the louvers that was obviously the place to tape for painting.
