Oil Pressure
I know that oil pressure should be at 60 @ 3,000 rpm. Does anyone know why on some occasions I'll run slightly less driving for a while ( 50 to 75 miles ). I can stop form 5-10 minutes restart and be @ that "magic" psi and other times it just stays at 60? Is there an oil pressure valve or something that is about to take a dump?
Porsche crazy now have a 1994 325i also
Old 03-09-2005, 12:12 AM
IROC's Avatar
I don't agree that oil pressure should be "60 @ 3ooo rpm". I would say that 10-15 psi per 1000 rpm is a better rule of thumb. So...you should be seeing 30-45 psi at 3000 rpm.
Having said that alot of things can affect the oil pressure (engine temps, etc.) and I also wouldn't trust the gauge as an accurate means of measuring oil pressure. I especially wouldn't trust your gauge if it "just stays at 60" sometimes. Oil pressure should vary with rpm.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 03-09-2005, 04:23 AM
I'd say, for the average 911, 30-45 psi at 3000 rpm at fully warmed up temps is even optimistic. 3 at 3000, 1 at 1000 2 at 2000 is the rule I have gone by. And in the summer when your stuck in traffic the pressure will be less. The temp goes up the oil gets thinner the pressure goes down.
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 03-09-2005, 04:32 AM
Wandered off somewhere...
Drdogface's Avatar
Replace the sending unit
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 03-09-2005, 05:37 AM
