47silver's Avatar
distributor ground wire?
there is a wire attached to my distributor that looks like a bare ground wire but it is not attached to anything, i have a msd 6a with points would anyone know if it should be attached?
Old 10-01-2002, 11:05 AM
Friend of Warren
No such thing. You should only have the one wire from your coil to the distributor.
Kurt V
Old 10-01-2002, 02:10 PM
There is a small braided ground wire from the dist body to the plate on which the points are attatched.
Is this what you mean?
Jeff
911T
Old 10-01-2002, 05:09 PM
47silver's Avatar
ground
the car runs good so i haven't really checked but will tonite
gary
Old 10-02-2002, 12:05 PM
Friend of Warren
Jeff
911T
Jeff, good thought. I just assumed he meant a wire hanging on the outside of the distributor.
Kurt V
Old 10-02-2002, 01:11 PM
Yea, but his car runs!
So it's definately not that one he's talking about
Jeff
Old 10-02-2002, 01:45 PM
Early_S_Man's Avatar
Porsche Crest
Since we have no clue what year car is being referenced here ... it is hard to say for sure!
But, all '69 - '77 Bosch CDI installations had a ground braid strap/shield that ran from the CDI-unit to distributor body, and also to the coil!
The schematic section below clearly shows the brained ground straps:
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-02-2002, 01:57 PM
47silver's Avatar
ground wire
sorry, the car is a 1975 911s 2.7l with cis and a msd in replace of the original porsche capaitive discharge setup.
maybe that is why the wire is not connected?
Old 10-02-2002, 06:15 PM
Mine doesn't - makes sense
It will have tommorow
Jeff
Old 10-02-2002, 07:31 PM
47silver's Avatar
i found out that the wire is the shield on the distributor wire it was separated.
sorry for the late post, just found this out.
gary
1975 911S Targa
Silver Anniversary Edition
Old 02-11-2003, 07:07 PM
Hi,
I have a mystery ground wire and this post basically described, but I still can't tell where the wire is supposed to connect. Here is a picture. Can someone tell me where it is supposed to connect to? Is it possible that I cut that wire when I installed the Pertronix? I don't remember.
Thanks!
Neil
'73 911S targa
Old 03-07-2005, 06:46 AM
Porsche Crest
Neil,
The ground strap originally had a large 'ring' style terminal lug [and a oversize M8 flat washer fit under it] on the stud that clamped the distributor body in place.
Warren Hall, Jr.
Old 03-10-2005, 11:11 PM
