distributor ground wire?
there is a wire attached to my distributor that looks like a bare ground wire but it is not attached to anything, i have a msd 6a with points would anyone know if it should be attached?
Friend of Warren
No such thing. You should only have the one wire from your coil to the distributor.
Kurt V No more Porsches, but a revolving number of motorcycles. |
There is a small braided ground wire from the dist body to the plate on which the points are attatched.
Is this what you mean? Jeff 911T |
ground
the car runs good so i haven't really checked but will tonite
gary |
Friend of Warren
Yea, but his car runs!
So it's definately not that one he's talking about Jeff |
Since we have no clue what year car is being referenced here ... it is hard to say for sure!
But, all '69 - '77 Bosch CDI installations had a ground braid strap/shield that ran from the CDI-unit to distributor body, and also to the coil! The schematic section below clearly shows the brained ground straps:
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
ground wire
sorry, the car is a 1975 911s 2.7l with cis and a msd in replace of the original porsche capaitive discharge setup.
maybe that is why the wire is not connected? |
Mine doesn't - makes sense
It will have tommorow Jeff |
i found out that the wire is the shield on the distributor wire it was separated.
sorry for the late post, just found this out. gary
1975 911S Targa Silver Anniversary Edition |
Hi,
I have a mystery ground wire and this post basically described, but I still can't tell where the wire is supposed to connect. Here is a picture. Can someone tell me where it is supposed to connect to? Is it possible that I cut that wire when I installed the Pertronix? I don't remember. ![]() Thanks!
Neil '73 911S targa |
Neil,
The ground strap originally had a large 'ring' style terminal lug [and a oversize M8 flat washer fit under it] on the stud that clamped the distributor body in place.
